Old 11-05-2019, 05:51 PM   #1
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
Anyone have clutch engaging at top of peddle travel?
My 2012 zl1 manual has 4000 miles on it, and was bought used. The car is all stock. But the peddle engages the clutch at the very top of peddle travel. I've gotten used to it somewhat. But my 2010 engages in the middle of travel. Which seems more normal. Since there is no adjustments I'm thinking there might be air in the system and needs bled. Anyone else have the same issue?
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
Old 11-05-2019, 06:34 PM   #2
ZL1 Maniac
ZL1 Maniac's Avatar
Drives: 2014 ZL1 Red Hot M6
My 2014 engages in the top 3/4 of travel....
One thing I've read to keep things healthy is to change the fluid in the reservoir
if it starts to look darker, seems some clutch dust can migrate into the shared reservoir.
I learned to like the engagement point after I figured out it's less pedal distance to dis-engage as well....
Happy Gear Bangin'
ZL1 Maniac is offline   Reply With Quote
Old 11-05-2019, 10:29 PM   #3
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I've driven 3 5th gen ZL1's. The engagement point is high (I like it there personally). You can get it to lower down a bit if you install the triple-disk Monster clutch, though...
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 11-06-2019, 05:48 PM   #4
lionssfan
lionssfan's Avatar
so sounds like just the way its designed then. I'm sure the fluid is ok with 4000 miles
2010
Edit Signature
Old 11-06-2019, 06:09 PM   #5
G8One2
Drives: 2014 Camaro 2SS
Its normal for our cars, from what I understand. I dont worry about it much, but it did take some getting used to coming from an auto trans, and not driving a manual for 15 years prior.
G8One2 is offline   Reply With Quote
Old 11-06-2019, 09:26 PM   #6
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Check out the RAM Pedal Adjuster
See this thread https://www.camaro5.com/forums/showthread.php?t=411141
camguynj is offline   Reply With Quote
