![]() Drives: 2013 camaro 2SS Join Date: Mar 2018
Squeaky brakes Help!!
My brake pads are still I decent shape (original pads) but I can’t stand the squeaking every time I brake , what did y’all guys do to help fix the problem.
Drives: 2010 Camaro Join Date: May 2014
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Keep the spring clips under the pins adjusted in the center of the calipers.
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Honestly I have tried about 10 brands of brake pads and almost all make noise on this car... I would get either the centric posiquiet 105. brake pads OR the autozone duralast gold brakes.
AZ brakes made by bosch for about $40, even after I cut off the roller skates they still make no noise. a lot of people here recommend hawk hps brakes but they were extremely noisy... |
I have AC Delco replacement pads. No roller skates, no noise and only $40 a set.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Squeaking brakes
moved to brake sub forum
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 Last edited by morepowerjoe; 12-18-2020 at 10:27 AM. |
