Old 11-06-2019, 06:56 AM   #1
GHOSST2012
Drives: 2012 Camaro SS
Stabilitrak Light After ZL1 Rear Swap
I swapped a zl1 diff axles and driveshaft into my ss. I now have the service stabilitrak lights on. I replaced both abs sensors and it didn't go away. What else could it be? I have not adjusted the tune for the different gear size yet.
GHOSST2012 is offline   Reply With Quote
Old 11-06-2019, 06:59 AM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Get it tuned for the other gear ratio. It thinks the wheels are spinning at 2 different speeds
ttshovel is offline   Reply With Quote
abs light, stabilitrak, zl1 rear end
