Old 11-07-2019, 06:03 PM   #1
lionssfan
lionssfan's Avatar
Drives: 2010 2ss camaro
whats new head unit is the hot one today to get?
I have a 2012 zl1 I want to replace the head unit. what is top of line brands and models. front and rear camara would be nice. maybe nav. input on face plate for playing music off my phone. any other options I missed thanks guys
2012 zl1 stock 7000 miles
2010
TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems.
Edit Signature
lionssfan is offline   Reply With Quote
Old 11-08-2019, 12:34 PM   #2
Cheap Guy
Cheap Guy's Avatar
Drives: 2011 Camaro SS
I’d say no matter what brand you get, try to get wireless CarPlay if you’re an Apple IOS person. The new IOS 13 made some major improvements and I’d love to have it wireless now.
My Little Mid-Life Crisis Cure!
First - 1997 Camaro 3800 Y87, M5, Green - Gone | Second - 1997 LT1 Z28, M6, Silver - Sold | Third - 1999 LS1 Z28, M6, Pewter, Almost Stock! - Sold
Current - 2011 Camaro SS, M6, black, 1LE suspension parts - Current
Cheap Guy is offline   Reply With Quote
Old 12-22-2019, 04:11 AM   #3
LillyPinon
LillyPinon's Avatar
Drives: camaro v8
Pioneers FH-X720BT could be a nice option, especially I like its sound controls and led display. You can also see one of the best double din head units here https://99carstereo.com/best-double-din-head-units-radio/ . On the other hand, if you want any head unit at a reasonable price then you should consider Kenwood KDC-255U. Due to the availability of a USB port, you can play music directly from your device.
However, if you want single din units and already have Alpine stereo then Alpine CDE-143BT Digital Audio Receiver could also be a good choice. Let's see what sound systems these companies offer in 2020.
LillyPinon is offline   Reply With Quote
Old 12-22-2019, 07:22 PM   #4
lionssfan
lionssfan's Avatar
Thanks guys, I just went for top of line I got the pioneer w8500nex double den. Front camera sounded appealing. I used the radio pro gm4101, with pak harnesses. Once I figured the wires out, watched a couple YouTube videos. Things went together well. Sounds better than stock. But going for a 5 channel amp and sub woofer now.
2010
Edit Signature
Old 12-22-2019, 11:18 PM   #5
bumblebeecamaro
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS
I just installed a Pioneer head unit using the iDatalink Maestro mounting system and it turned out awesome. It took me three days to do the install because I ran in to some issues with my OEM backup camera that normally displays the image on my rear view mirror which sucked big time. So I ended up buying a new camera and running the video feed from the back all the way to the new head unit. The Pioneer is awesome as it pretty much has everything I wanted including wireless Carplay which was a must have for me. The iDatalink Maestro system is sweet too. It gives my dash a whole new look while keeping all my original creature comforts along with adding an OBD2 feed that can display a ton of different engine parameters on my new Pioneer.
The project cost me about $800 in parts and about three days of work. It's been over 25 years since I've installed a car stereo so I was a little rusty. But the end result is well worth it.
bumblebeecamaro is offline   Reply With Quote
Old 12-25-2019, 11:07 AM   #6
imponte
imponte's Avatar
Drives: '10 Camaro SS
Sony ax5000 and Pac rpk-5 would be nice ��
imponte is offline   Reply With Quote
Old 01-30-2020, 08:00 AM   #7
12oclockshadow
Drives: 2012 ZL1 M6
we need some pics here. I'm considering a new head unit on my 12 ZL1.
FBO. Cammed. Flex fuel.801whp/741wtq on e85
12oclockshadow is offline   Reply With Quote
