Old 11-09-2019, 08:15 AM   #1
1fast
8.60 @ 157 @ 4200lbs
1fast's Avatar
Drives: 2010 Gen 5
Putting BMR suspension to work
Dialing in my BMR suspension refine tune and work on suspension faster times to come 8.6 cat at 4200 lbs
2010 camaro twin turbo 8.60 @ 157 full weight 4200
1fast is offline   Reply With Quote
Old 11-09-2019, 01:04 PM   #2
1fast
1fast's Avatar
Drives: 2010 Gen 5
Mir track testing
https://youtu.be/X1Ieo7UR7FQ
Old 11-22-2019, 07:40 AM   #3
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
This thing flies for a "true street car". Cant wait to see what next year brings.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 11-22-2019, 09:18 AM   #4
PhantomBlack
PhantomBlack's Avatar
Drives: 2014 Camaro 2SS
whats your BMR setup? I'm going to get trailing arms on black friday.
PhantomBlack is offline   Reply With Quote
Old 11-22-2019, 11:39 AM   #5
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
+1
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 11-23-2019, 06:46 AM   #6
1fast
1fast's Avatar
Drives: 2010 Gen 5
Suspension
bmr drag pack
Cradle bushing pro
Diff bushing
Extreme anti roll kit
Adjustable toe rods
Big part is a good alignment
Old 11-23-2019, 09:09 PM   #7
PhantomBlack
Thank you! Looks like a solid set up. I'm no where close to the power your putting down, but I do need help keeping the car straight.
Old 11-24-2019, 11:33 AM   #8
1fast
1fast's Avatar
Drives: 2010 Gen 5
What mods have you done
Old 11-25-2019, 12:50 PM   #9
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
Daaaaaamn..you're flat scooting, sir!
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 12-05-2019, 03:35 PM   #10
phat9le
Drives: GMC Yukon XL Denali
60ft
What's the 60ft if you don't mind me asking? Stock diff as well?
phat9le is offline   Reply With Quote
Old 12-06-2019, 08:51 AM   #11
1fast
1fast's Avatar
Drives: 2010 Gen 5
1.374 sixty foot ran stock diff with stock gears up to 8.90 then switched out to s60 independent rear
Old 12-11-2019, 02:45 PM   #12
rmcbee
rmcbee's Avatar
Drives: 2013 ZL1
Originally Posted by 1fast View Post
bmr drag pack
Cradle bushing pro
Diff bushing
Adjustable toe rods
What do you mean exactly by a good alignment? Ty
rmcbee is offline   Reply With Quote
