Old 11-11-2019, 08:25 PM   #1
ridndirty1000
Drives: 2000 camaro
Direct bolt on 750whp fuel pump
What is the best reasonably priced fuel pump that is direct plug and play drop in fuel pump that can handle forced induction e85 750 whp. Thanks in advance.
ridndirty1000 is offline   Reply With Quote
Old 11-11-2019, 09:14 PM   #2
Rons1le
Rons1le's Avatar
Drives: 2015 Camaro 2SS RS 1LE AGM
I am looking at one of these. I made 660rwhp on 93 with the ZL1 pump and ID1050X injectors on 10LBs boost.
https://weaponxmotorsports.com/produ...-zl1-gen-5-lsa
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
Rons1le is offline   Reply With Quote
Old 11-11-2019, 09:20 PM   #3
ridndirty1000
Drives: 2000 camaro
Hmm that may work. Not a bad price either.
Old 11-11-2019, 09:22 PM   #4
Rons1le
Rons1le's Avatar
That's what I was thinking also. I would cut the whole under the seat and try it.
Old 11-11-2019, 09:24 PM   #5
ridndirty1000
Drives: 2000 camaro
Trap door. I don’t think I’m brave enough for that.
Old 11-11-2019, 09:26 PM   #6
ridndirty1000
Drives: 2000 camaro
If there was a really detailed write up maybe. I haven’t looked
Old 11-11-2019, 09:33 PM   #7
Rons1le
Rons1le's Avatar
Yes there is a few detail write-ups with exact measurements so you do not cut wires.
Old 11-11-2019, 09:40 PM   #8
ridndirty1000
Drives: 2000 camaro
I’m hoping some else chimes in for more options. I will be calling a few vendors tomorrow also just hoping someone has experience with some of them
Old 11-11-2019, 09:49 PM   #9
eLeSthree
Drives: 2011 Camaro SS 6sp
The cts v has dual pumps from the factory. You need the cts v bucket for those pumps to be “drop in”.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 11-11-2019, 10:22 PM   #10
lpope
Drives: 2014 Camaro SS M6
Have ZL1 pump and DSX pump.....should Be what you want.
A little boost, bit of the juice, some corn, and a big ole cam.
lpope is offline   Reply With Quote
Old 11-11-2019, 10:40 PM   #11
ridndirty1000
Drives: 2000 camaro
That was going to be last option just wanted to see a direct bolt in no add ons
Old 11-11-2019, 11:03 PM   #12
Rons1le
Rons1le's Avatar
Livernois and lingenfelter make a direct drop in not cheap though.
Old 11-12-2019, 09:38 AM   #13
ridndirty1000
Drives: 2000 camaro
Yeah but just the aux pump is 1000 plus around 300 for zl1 pump
Old 11-12-2019, 10:10 AM   #14
jeff657756
Drives: 2014 SS 1LE
Doesnt get much better price/performance wise with the aux pump/zl1 combo. Most of us that have done it would recommend just doing a dual squash or fore setup. Do it once and forget it. Dont cheap on fuel system.
jeff657756 is offline   Reply With Quote
