Old 12-14-2009, 02:37 PM   #1
Anthony @ LG Motorsports
Drives: 1994 1LE / 2006 Z51 Corvette
**530 RWHP NA / 743 RWHP Bottle LG Motorsports G6X3 cam and Head package**
Hi guys,
We did a little update to our local customer's 2010 6spd manual Camaro last week and added some of our ported and milled LS3 cylinder heads and FAST 102mm intake manifold. Now we have not ported the intake yet, and he is still using a stock 90mm throttle body for the time being. The results on both HP and TQ were very nice.
Just as a recap, the runs you are looking at above include:
  • LG Long Tube headers
  • 100mm Cold air induction
  • G6X3 cam kit
  • LG ported LS3 heads (530hp run)
  • FAST 102mm intake manifold (530hp run)
Once that was finished we added a 150 HP nitrous shot. Pulls below show nitrous before and after the heads and intake manifold. Sorry for the signal loss between 4000 and 4500 RPM.
For those of you keeping track here is the above dyno also with the curve of the car with bolt on's only (LG 1 7/8" headers, 100mm Cold Air, MagnaFlow mufflers and tune).
A little bit of porting work to the intake and addition of a larger throttle body should see even more gains!!
Anthony
LG Motorsports
972-429-1963
anthony@lgmotorsports.com
Anthony @ LG Motorsports is offline   Reply With Quote
Old 12-15-2009, 01:19 PM   #2
navyblueSS
Drives: 2002 Camaro SS
Awesome numbers!
2015 1LE - CAI intake, TSP longtubes,
NPP, Futral Motorsports tuned, BMR 1"lowering springs, BMR trailing arms
navyblueSS is offline   Reply With Quote
Old 12-15-2009, 01:51 PM   #3
I want those HP numbers in my Camaro
Old 12-19-2009, 01:38 PM   #4
Louis @ LG Motorsports
Drives: 2010 SS/RS 2009 CG Z06
750 rwhp on a stock bottom end car, not bad!!
Louis @ LG Motorsports is offline   Reply With Quote
Old 12-21-2009, 11:19 AM   #5
21STCENTURY
Drives: Z28/700HP, CTSV/850HP, Viper/725HP
Very Nice Louis,
You could have had a bunch more views if you waited 2 or 3 days to
post that you added the 150 shot of Nitrous to get the 742 RWHP
J.P.
21STCENTURY is offline   Reply With Quote
Old 12-22-2009, 10:27 AM   #6
Sam88gta1
Drives: 2010 Camaro SS / 2006 CC Duramax
Originally Posted by 21STCENTURYMUSCLECARS View Post
Very Nice Louis,
J.P.
Why in the world would we want to do that?
I stopped by yesterday to tour the new shop. The place is top notch!
Sam88gta1 is offline   Reply With Quote
Old 12-22-2009, 11:17 AM   #7
OrangeChevyII
Drives: 2010 RS/SS2
Did you forget to mention it was on pump gas?
2010 SS/RS SIM
First to run 11's (11.83)on a stock long block.
First to run 11's cam only
First to run 11's all motor
First to run 10's (10.96) and did it with a 100% bonestock long block and a power adder (nitrous)
First to run 10's (10.55) on motor in 2010 Camaro
First to break into the 5's (5.97) 1/8th mile
First to cut a 1.5X sixty foot
First to cut a 1.4x sixty foot
First to car to cut a 1.3x 60ft
OrangeChevyII is offline   Reply With Quote
Old 12-23-2009, 04:56 PM   #8
Its on pump gas
Old 12-23-2009, 06:20 PM   #9
OrangeChevyII
Drives: 2010 RS/SS2
What about a stock fuel system?
2010 SS/RS SIM
Old 12-24-2009, 11:56 AM   #10
Stock fuel system
Old 12-24-2009, 12:14 PM   #11
Pope Designs
Drives: 2013 ZL1 Rally Yellow
We just installed a ProCharger on my car and we had to upgrade to the Fastlane duel pump as we were running out of gas. I guess every car is different. it was making about 640ish and 7lbs of boost.
Bryan
Pope Designs is offline   Reply With Quote
Old 12-28-2009, 02:21 PM   #12
Bryan
You also have to remember it takes power to turn the blower, and there by increases the fuel demands on the car because it makes more than it actually gets to put to the ground due to the loss of power from the blower turning.
Nitrous systems typically take care of fueling on their own if it is a wet kit. Dry kits it depends on how much the car is making on what fuel upgrades would be needed.
Old 02-28-2010, 02:21 PM   #13
tp_preformance
Drives: 2006 gt500 super snake
those are some wicked number is that a package you put together? it made 530 with the 6 speed manual what kind of power are you making with that set up on a auto 6 speed?
tp_preformance is offline   Reply With Quote
Old 02-28-2010, 04:08 PM   #14
OrangeChevyII
Drives: 2010 RS/SS2
Updated numbers, 539 N/A
2010 SS/RS SIM
**530 RWHP LG Motorsports G6X3 cam and Head package** Anthony @ LG Motorsports Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 45 02-03-2014 10:52 AM
