Old 11-14-2019, 11:36 AM   #1
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Brembo Brakes from 2014 Corvette?
Are the brake calipers for 2010-2015 SS models the same as the Corvette Stingray 2014? The pads seem to be exactly the same shape minus the rollerskates, but calipers have different part numbers.
Reason I ask is I wanted to install some Corvette pads on the front SS calipers, but it looks like I might need to use Corvette brake pins/hardware instead of the stock SS hardware.
Any insight appreciated, thanks
TommyTheCat is offline   Reply With Quote
