Old 11-14-2019, 09:19 PM   #1
iDivinst
Drives: 2012 Camaro 2LT
ARH HFC’s
I heard people getting cels installing this, what type of fixes can be done for this?
Also, is it worth it to get the solo hfc’s instead because they apparently don’t get cels?
iDivinst is offline   Reply With Quote
Old 11-15-2019, 12:24 AM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Tuning. Solo HFCs don't throw the code because of the O2 defouler. If you throw them on with the ARH it will have the same effect.
DSX_Camaro is offline   Reply With Quote
Old 11-15-2019, 02:01 AM   #3
iDivinst
Would this work alright
http://www.bigdaddiesgarage.com/straight-cel-fix.html
Just not sure which bank# upstream or downstream.
Old 11-15-2019, 05:00 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
I think so yes. And it would be your downstream sensors. Upstream is AFR. Downstream is emissions.
Old 02-26-2020, 10:13 AM   #5
Summit13
Summit13's Avatar
Drives: 2013 Chevy Camaro RS
it indeed throws a code and the O2 sensors don't necessarily work to completely get rid of the CEL. I would recommend a tune more than anything.
2013 LFX Chevy Camaro RS
Performance Mods: K&N Typhoon Cold Air Intake, ARH Catted Downpipes, Flowmaster Axle-Back exhaust, Hawk Front and Rear Ceramic Brakes, Baer Drilled and Slotted rotors.
Cosmetic Mods: z28 Replica wheels, z28 style front splitter
Summit13 is offline   Reply With Quote
