Old 11-16-2019, 09:32 PM   #1
plaincamarojoe
Drives: 2014 Camaro 1LT
Is it my PCM/ECM? PLEASE HELP!
I have a 2014 1LT V6...I decided to replace the original battery before it gets too cold out, so I replaced it with a 'Platinum' AGM battery from Advance auto.
It has been running 15 to 15.3 volts almost always [all week] as well as periodically flashing the check engine light. I bought a cheap OBD 2 reader
and I get the following codes ; P1682 Driver 5 / Line 2 and code P2535
Ignition 1 switch circuit high voltage {PCM]
From research one says to replace ignition switch / other says to replace the
PCM/ECM . I'm not sure what I did wrong replacing battery, and I dont want to keep replacing parts. Car was fine until the battery swap. Tried to reset/flash
with battery disconnect and fuse pull..still overcharging.
PLEASE HELP / MY ONLY CAR. THANK YOU!
plaincamarojoe is online now Report Post
plaincamarojoe is offline   Reply With Quote
Old 11-21-2019, 03:53 PM   #2
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
15 volts is too high, alternator overcharging will cause all sorts of problems, but voltage is supposed to be PCM controlled. Could be a bad alternator, PCM, etc. but needs a proper diagnostic to be sure. If the problem started immediately after battery installation, you may have connected it incorrectly while trying to put it in?
TommyTheCat is offline   Reply With Quote
Old 11-21-2019, 05:46 PM   #3
G8One2
Drives: 2014 Camaro 2SS
15v is not too high for AGM batteries. The vehicle comes stock with an AGM battery and a charging system designed for AGM batteries. 15v or higher would be too much for a standard wet cell battery, but AGM batteries are designed for this. The vehicles charging system also monitors battery state of charge and adjusts voltage accordingly. Your fault codes are not likely related to the battery. A circuit high fault is usually an open circuit. You need a wiring diagram and a digital multimeter to check the circuit in question.
G8One2 is offline   Reply With Quote
Old 11-28-2019, 08:23 AM   #4
plaincamarojoe
Charging issue solved
Apparently when I swapped batteries, the computer saw a low voltage and threw codes to alert. Strange the DIC never threw an alert. The voltage was not being regulated as it normally would so it seemed to go into a default mode.and acted as if there was very a weak battery,running full charge mode.
I stopped by the local dealership and they reset the codes and its running all normal ...diagnostics ran good too. Mechanic said he wasnt sure why it did what it did,,,but all is normal. Luckily no charge. huh?
I had a 13 impala with a DIC like the Camaro, over the winter the battery connections grew a beard and I didnt know there was a problem until the alternator brushes bottomed out and took out the battery...$400 bucks plus..
I think the DIC was a little underthought in its design, and by the time your notified of an issue you may only have enough time to get to the next exit on the freeway. Had I kept driving it who know if damages would occur. I guess if you change batteries, use a method to maintain voltage to the PCM. Some cars require it, but I havent heard of camaros needing it. Could have been ugly.
Thanks to you guys who replied !
Old 11-28-2019, 09:12 AM   #5
xstuntman
Drives: 2012 Victory Red LFX
Glad you figured it out.
That's the first time I've heard of that happening after a battery swap though.
A free fix too.
Sweet!
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 03-23-2025, 04:36 PM   #6
malibupaul
Drives: 2013 Camaro 2LS
My stock 2013 LS radio is going crazy. It runs between 15.1 and 15.2 volts. I ran the car for over an hour and this voltage was constant. I soon as I got home I checked the battery. It read 12.63 volts. I started it and it read 14.9 volts, but after 60 seconds or so, it went to 15.1, 15.2 again. The radio works fine in accessory mode. Also works fine with the engine running but the alternator disconnected. The dealer swapped out the alternator but that didn’t fix it. Is it overcharging and could the new alternator (voltage regulator) be bad?
malibupaul is offline   Reply With Quote
