Old 11-16-2019, 09:38 PM   #1
plaincamarojoe
Drives: 2014 Camaro 1LT
Is it my PCM/ECM? PLEASE HELP!
I have a 2014 1LT V6...I decided to replace the original battery before it gets too cold out, so I replaced it with a 'Platinum' AGM battery from Advance auto.
It has been running 15 to 15.3 volts almost always [all week] as well as periodically flashing the check engine light. I bought a cheap OBD 2 reader
and I get the following codes ; P1682 Driver 5 / Line 2 and code P2535
Ignition 1 switch circuit high voltage {PCM]
From research one says to replace ignition switch / other says to replace the
PCM/ECM . I'm not sure what I did wrong replacing battery, and I dont want to keep replacing parts. Car was fine until the battery swap. Tried to reset/flash
with battery disconnect and fuse pull..still overcharging.
PLEASE HELP / MY ONLY CAR. THANK YOU!
plaincamarojoe is online now Report Post
plaincamarojoe is offline   Reply With Quote
