Old 12-14-2009, 07:57 PM   #1
55Designs
Drives: 2010
Body and Paint Shop Gurus' got a question regarding plastic on exterior
On the slight texture on the ABS rear diffuser, grill, and XM ant can that be prepped and painted where you wont see any texture? I had good luck with smaller parts but never tried a grill or diffuser before.
Does the plastic have to be sanded down all the way or can you spray some sort of polyester primer surfacer over the plastic to cover the texture?
I am most concerned on the rear diffuser since its alot of material to sand and its flimsy as heck already.
I just hate the texture of these parts.
55Designs is offline   Reply With Quote
Old 12-14-2009, 08:04 PM   #2
ottobody
Drives: 2010 trans am/camaro
we use a flex addative poly primer for the plastics which allows it to bend you could prbly scuff your plastic down and spray that and then spray color and clear with the flex addative in it also
ottobody is offline   Reply With Quote
Old 12-14-2009, 08:06 PM   #3
55Designs
Drives: 2010
Otto but will that hide the texture?
Old 12-14-2009, 08:13 PM   #4
orange10s.c.
orange10s.c.'s Avatar
Drives: IOM 2SS RS M6 sunroof
I've always used a plastic adhesion promoter (bulldog) first. First clean with denatured alcohol then use a red scothbrite, apply adh. promoter then use a good 2 k primer with flex additive in then sand smooth then apply paint. It should come out like the body. !!
Old 12-14-2009, 08:19 PM   #5
55Designs
Drives: 2010
Sounds good because my diffuser is already turning white from the wax. I am going to have the diffuser done in a satin black but i want it smooth.
I have seen lots of butchery in NY for attempts to paint plastic on Range Rovers and Bimmers.
I also want to fill in the waffle design where it meets the bumper so its smooth.
Ohter parts will be body color gloss.
Old 12-14-2009, 08:21 PM   #6
ottobody
thats what i was getting at lol
Old 12-14-2009, 08:21 PM   #7
ottobody
the poly primer will just build it up then you will need to block it out smooth
GM bulletin on Perceived Paint Mismatch on Door and Quarter Panel Paint Appearance Tran Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 53 07-17-2013 02:16 PM
GM bulletin on Perceived Paint Mismatch on Door and Quarter Panel Paint Appearance Tran 5th Gen Camaro SS LS LT General Discussions 114 04-16-2012 04:04 PM
Question About Red Jewel Paint Code JoeKay 5th Gen Camaro SS LS LT General Discussions 3 12-10-2009 08:47 PM
Good DFW paint shop for stripes? 68RS USA - Texas 4 11-06-2009 09:01 PM
Custom Paint Shop in my area? ZZcamaro USA - NY / NJ / PA 8 03-31-2009 08:48 PM
