Old 11-20-2019, 01:17 PM   #1
geekdrummer
geekdrummer's Avatar
Drives: 2014 Camaro LS
Smile Backend Jacked Up on 2014 Camaro LS
I am sure you all remember the 1970's Camaro with 50's tires on the back and jacked up a bit. Man those things look bad to the bone in my opinion.
Has anyone ever jacked up at 5th Gen Camaro? If so, how do you do that or what do you use to accomplish that? It may look dumb, I just have never seen a 5th Gen jacked up.
Anyone have photos?
Thanks very much!!!
geekdrummer is offline   Reply With Quote
Old 11-20-2019, 01:31 PM   #2
Sxren_Camaro'13
SEAHAWKS FOR LIFE!!
Sxren_Camaro'13's Avatar
Drives: '13 Mod Camaro LS
Anyone have photos?
Thanks very much!!!
Like this?
Sxren_Camaro'13 is offline   Reply With Quote
Old 11-20-2019, 01:35 PM   #3
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
I think he is meaning more "gasser" style. Like in the 70s when they lifted the rears to stuff as big of a tire as they could in the back. See it a lot in old novas/gtos/etc..
Sorry OP, never seen someone do that on a 5th gen, so not really sure bout that one
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 11-20-2019, 01:39 PM   #4
Sxren_Camaro'13
SEAHAWKS FOR LIFE!!
OOOOHH that lol i haven't seen that ever on a 5th gen
Old 11-20-2019, 02:01 PM   #5
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Hard to do due to the nature of the independent suspension. If you recall, those older cars were leaf sprung and straight axle rear ends.
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 11-20-2019, 02:16 PM   #6
Benman
Benman's Avatar
Drives: 13 IOM 2ss RS manual
This is a "GASSER";
I think this is more what the OP is referring to, it was THE LOOK back in the 70's:
You could get somewhat of a raked look by dropping the front with lowering springs, but probably pretty hard to get the drastic rake of the old air shocked cars.
Rectangular Dollars will beat Cubic Inches
Benman is offline   Reply With Quote
Old 11-20-2019, 03:13 PM   #7
RankSS
Drives: 2010 Camaro SS
This thread is destined to be a classic.
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 11-20-2019, 03:16 PM   #8
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
the fancy camaro computer will not like a huge difference in tire size, so you cannot go that way. It would have to be a suspension type lift in the back.
Old 11-20-2019, 03:37 PM   #9
Jay_LHD3
Jay_LHD3's Avatar
Drives: 2019 F150 RCSB Abyss FX4
This thread reminded me of LittleMT's car. It was only lowered in the front and looked good with the Forgestars.
https://www.camaro5.com/forums/showthread.php?t=216002
Jay_LHD3 is offline   Reply With Quote
Old 11-20-2019, 04:37 PM   #10
600hp-lpe
Drives: 2010
if you install coil over shocks, your ride height will be adjustable.
Most people go down - you could go up if you wanted to.
Not sure how much you want to elevate the rear...
600hp-lpe is offline   Reply With Quote
Old 11-20-2019, 04:58 PM   #11
redcoats1976
did this to my hot rod pontiac back in the day.be warned that ride quality and handling will suffer...but it will look cool.
Old 11-20-2019, 05:28 PM   #12
geekdrummer
Oh my gosh! You guys have made my day!! You all are freaking awesome! I just remember how cool it used to look where the backend was lifted about 6 inches or so higher than the front end. I did not know what you called it. Maybe "jacked up" is a Mississippi term (where I am from). Lowering the front is a great idea Jay_LHD3. LittleMT's car is bad ass looking!
Old 11-20-2019, 05:38 PM   #13
Fred 6528
Fred 6528's Avatar
Drives: 2011 ss
Might give you a nose bleed
Fred 6528 is offline   Reply With Quote
Old 11-20-2019, 05:38 PM   #14
BehindBlueI's
Drives: 2011 Camaro SS
It's a solid performance mod. You are going to go much faster because you are always going down hill...
BehindBlueI's is offline   Reply With Quote
camaro ls, jacked up
