Old 11-27-2019, 06:27 AM   #1
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
5 inch motor setback
I plan on doing some no prep stuff the 2020 season so decided to move the motor back since I'm redoing all my turbo piping anyways. This is the first time setting the motor in, it will need to go in/out a few more times to get clearance I'm happy with
ttshovel is offline   Reply With Quote
Old 11-27-2019, 07:38 AM   #2
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Damn you are getting serious.
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 11-27-2019, 08:45 AM   #3
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
So much room for activities!
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 11-27-2019, 09:43 AM   #4
ttshovel
ttshovel's Avatar
Yes sir! Making the switch to methanol
Yes! Im moving turbo front and center of nose, dual 4inch bullhorns
Old 11-27-2019, 09:54 AM   #5
NoDakZ/28
NoDakZ/28's Avatar
Can't wait to see it!
2014 1LE - Sold
Old 11-27-2019, 10:03 AM   #6
v8
v8's Avatar
Drives: 19 Z06
Nice!!!
Gone but not forgotten:
1974 Corvette Stingray 454
1986 Z28
2009 Mustang GT convertible
2012 45th 2SS Vert
2013 ZL1 M6
2014 Zl1 M6
2014 GT500
2016 Challenger Hellcat M6
www.youtube.com/c/garageking
v8 is offline   Reply With Quote
Old 11-27-2019, 10:19 AM   #7
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
How is this affecting I/C and does the rear suspension need any adjustments?
l8tr
PEACE
Old 11-27-2019, 10:28 AM   #8
ttshovel
ttshovel's Avatar
l8tr
PEACE
Yes I will be extending ic, center of gravity will be moved back so it shouldn't need to transfer as much weight, having more on the rear tires.
Old 11-27-2019, 02:01 PM   #9
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Out of control! Lol
Always enjoy watching your mods and your car progress.
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 11-27-2019, 07:20 PM   #10
ttshovel
ttshovel's Avatar
Originally Posted by Jayjellyfish212 View Post
Out of control! Lol
Thank you!
Got the mid plate in after a lot more cutting. Header clearance is going to be close so I ordered those. Before welding the plates in I will make sure clearance is good
Old 11-27-2019, 07:36 PM   #11
Jayjellyfish212
Drives: 2014 1LE
Looks like your gonna need to open up the trans tunnel even further back to from looking at the pictures so the trans sits in there. Certainly awesome watching you accomplish this motor set back. A lot of work but should definitely be worth it when done.
Old 11-27-2019, 07:43 PM   #12
ttshovel
ttshovel's Avatar
Its gonna be close, no doubt about it. I'm gonna lower the motor about a 1/4" as well so that should help a teeny tiny bit lol. But I'm fully prepared to cut more. I ain't scared
Old 11-27-2019, 08:00 PM   #13
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Do you need a new, custom length driveshaft with this monstrous monstrosity, with moving it back 5 inches?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 11-27-2019, 08:18 PM   #14
ttshovel
ttshovel's Avatar
Should just be a straight 5 inches off and a rebalance but I'll remeasure to be sure. Any weight I can get off this 4 inch steel shaft the better lol
