![]() Drives: 2019 ZL1 Join Date: Nov 2009
factory fog light switch
Has anyone tried to install the factory fog light switch on an rs? Looking to upgrade my drl to a tuue fog light but id like to use the factory switch for a clean looking install.
Mark
NJWHMH / Ordered-05.06.09 / Status-Delivered 2SS/RS VR, Blk Rally Strips, 6AT, Blk Int, Roof NKDPBG / Ordered-05.15.09 / Status-Delivered 2SS/RS IOM, 6AT, IO Int, Roof |
400HP used to be enough..
Drives: 2010 2SS rs manual Join Date: Aug 2009
This can't be done easily. The non rs foglight switch is not a simple switch. I believe it will require a reprogram of the BCM. You can read about the theory of operation in my thread here http://www.camaro5.com/forums/showthread.php?t=47925. Read post #41.
Build thread: http://www.camaro5.com/forums/showthread.php?t=47925
Thanks Frank,
ill give it a shot |
![]() Drives: '10 Camaro 2SS/RS CGM LS3 A6 Join Date: May 2009
Somebody did try swapping the switches, but that didnt work, it was discussed a bit in the DRL/fog thread linked in my signature.
- 2010 Camaro 2SS/RS CGM LS3 A6 "Lurch" - FLYNGSS -
![]() Some ProCharger, Alky, CompCams, Brian Tooley, Holley, Livernois, K&N, Ridetech, DSS, Kooks, JDP Motorsports, Pfadt, BMR, Prothane, Weld, M&H, Mickey Thompson, RKSport, Elite, Garys, Defenderworx, Anvil, etc. |
#6 |
thanks for the info
| dome light switch broken! | light-my-firebyrd | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 5 | 10-20-2009 05:03 PM |
| Issue with the instrument panel/interior light dimmer switch | topgun1 | 5th Gen Camaro SS LS LT General Discussions | 6 | 10-15-2009 05:21 PM |
| fog light switch? | chevy 3 | 5th Gen Camaro SS LS LT General Discussions | 11 | 07-03-2009 05:35 AM |
