Old 11-28-2019, 11:42 PM   #1
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Coilover install
Hey guys,
So I wanted to bring up something about my car that’s been bother me for awhile now. I did pedders xa coil overs on my camaro. Install went easy enough. As I was going through the instructions provided and plenty of YouTube videos.( some by Justice Pete, and guys with BC coil overs as the are nearly identical) I had to extra aluminum bushings/spacers that came with the kit. I have read everything I could and looked at a ton of pictures. But can’t seem to figure where they would go. Car drives great and have put 500 or more miles on as is. Here are pictures of the extra components. My front and rear coil overs set up. Maybe you guys will see something I don’t. Thanks in advance
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 05-30-2021, 05:18 PM   #2
Lnch Mny
Lnch Mny's Avatar
Drives: IBM Camaro
Did you ever figure out what these are for? I also had 2 small black bushings that I think are for the sway bar end links.
Lnch Mny is offline   Reply With Quote
Old 08-30-2021, 07:14 AM   #3
kleanSS
Drives: 2011 SS
I had the same extra parts though in my case I used the Pedder camber plates instead of the stock top hats. So, not sure what they are for either.
kleanSS is offline   Reply With Quote
Old 09-28-2021, 10:50 PM   #4
Shodown
Shodown's Avatar
Drives: 2014 ZL1
Yup. I have the same 2 parts after my install as well.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
Shodown is offline   Reply With Quote
Old 09-29-2021, 06:48 AM   #5
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Based on my motorcycle experience, do they fit between the spring and adjusting collar? Typically there's something there to keep the spring centered, especially when adjusted spring preload.
