Old 11-29-2019, 06:36 AM   #1
neil4374
Drives: Camaro SS 2011 L99
Winter storage
Hey,
Any advice would be appreciated.
I live in South Korea and it gets real cold here.
I decided not to drive my car from December to the end of March.
I will park it up outside and cover it. It has summer tyres on and I want to know if there is risk of the tires getting damaged it getting cracked. Even if the car isn’t being driven.
Temperatures will probably be -15 to -20.
What are your thoughts?
Thanks
neil4374 is offline   Reply With Quote
Old 11-29-2019, 07:59 AM   #2
Iron Lung Jimmy
Drives: Iron Lung, Jimmy
-15 to -20 Farenheit or Centigrade?
Iron Lung Jimmy is offline   Reply With Quote
Old 11-29-2019, 08:06 AM   #3
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Tires should be fine. Make sure they have the proper inflation level and maybe add just a few lbs. more. That’s what I do and it gets plenty cold here, as well.
0stones0 is offline   Reply With Quote
Old 11-29-2019, 08:31 AM   #4
neil4374
Centigrade
Old 11-29-2019, 08:32 AM   #5
neil4374
Thanks
Have you left summer tires on in -15 to -20c?
Old 11-29-2019, 08:34 AM   #6
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Check antifreeze strength.
Fill fuel tank.
Old 11-29-2019, 10:01 AM   #7
neil4374
Fill fuel tank.
Thanks. I read about what you suggested. I bought some fuel additives and will check the antifreeze.
I am concerned about the summer tyres cracking evening if not driven.
Old 11-29-2019, 01:17 PM   #8
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
I have stored my car at -20 to -40C in Canada and never had a problem. Battery in the house, I use Amsoil Zrod (anti-corrosive agent in it). Never had problems to with tires which were always summer tires. Stored from Nov to March.
I do not leave a lot a gas and never put additive in it. It's easier to empty the tank of bad gas if ever there's a problem in the spring.
I do start it maybe 2/3 times in the winter...
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 11-29-2019, 03:02 PM   #9
neil4374
Smile
-40! Wow.
Thanks for the advice/ information
Old 11-29-2019, 03:50 PM   #10
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
Originally Posted by neil4374 View Post
Thanks
I have. They'll be fine.
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 11-29-2019, 03:59 PM   #11
neil4374
Talking
KW
Thanks, appreciate the advice
Old 11-30-2019, 04:55 AM   #12
chevy pilot
They survive well in winter.
Old 11-30-2019, 05:30 AM   #13
neil4374
Thank you
Old 11-30-2019, 01:04 PM   #14
KW Baraka
KW Baraka's Avatar
At most, you'll want to consider placing the car on jack-stands so the tires won't have flat spots for sitting from too long where they touch the pavement.
But even if that happens, once you drive the car a 15-20 kilometers and warm up the tires, they should regain their shape and roll fine.
KW
