Old 11-29-2019, 08:20 AM   #1
Powered1le
Powered1le's Avatar
Drives: 2014 2ss 1le
Service stability on
Just want to know if this has happened to anyone else. So I was driving on the highway and my service stability came on. The car started jerking so I got of the highway and heard
a ticking sound. Can someone inform me of what kind of problems I'm having.
Thanks
2014 camaro 2ss/rs 1le [muffler & resonator delete, x-pipe , roto fab cai, 305 35 r20 rear tire 285 35 r20 front goodyear f1 supercar,1 7/8" tsp long tube headers with high flow cats, tsp Prc heads, K1 rods, Wisco pistons, 522whp 495tq, dynojet, btr stage3 cam kit, arp head studs and arp bolts.
Powered1le is offline   Reply With Quote
Old 11-29-2019, 12:16 PM   #2
HDRDTD
I had an issue with my 15 Malibu last year very similar. I could hear a ticking sound from time to time seemingly coming from one of the front wheels, then after a while the 'Service Stability' light came on.
Took the car to the dealer and they discovered that a flake of rust came off one of the front brakes (rotor?), dropped down and ended up lodging itself in between the wheels speed sensor and it's reluctor wheel, preventing the car from reading the wheels speed.
Old 11-29-2019, 01:16 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
So it was only the Service Stabilitrak light and nothing else?
Is the car running ok, no ticking when stopped, correct? Just making sure you didn't get multiple warnings along with the Stabilitrak. Also, what do you mean by the car was jerking?
Old 12-01-2019, 07:00 AM   #4
Powered1le
Powered1le's Avatar
The car does have a ticking sound when I stop. I runs find just but when I stop it sound rough and the the stabilitrak comes on and goes of when I start driving.The jerking was like I had a very big cam in it. I guess I should have said rocking not jerking.
Old 12-06-2019, 01:40 PM   #5
Rustymelon
Rustymelon's Avatar
Drives: 2014 2SS/RS Convertible
Is it an L99? This is a common symptom when the AFM starts to go out. I've experienced this first hand. If your service engine light comes on, don't play around.
Rustymelon is offline   Reply With Quote
Old 12-06-2019, 02:25 PM   #6
608RS
608RS's Avatar
Drives: 2015 2ss
my thought too at first but then i saw OP has a 1LE. hopefully it's nothing too serious.
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
Old 12-06-2019, 02:56 PM   #7
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Sounds like a misfire. get it checked out you don't want to drive with a misfire.
Greenhornet2 is offline   Reply With Quote
Old 12-07-2019, 06:08 PM   #8
Powered1le
Powered1le's Avatar
I have a mis fire in cylinder 7. Did a compression check and it was good swapped the coil packs and still the same. Also pulled the injector cable and no change. Changed the sparkplugs also.
Old 12-07-2019, 06:32 PM   #9
Greenhornet2
You mean you unplugged the injector for #7 and no change? That wouldn't really tell you much about the injector just that the misfire is on #7. Make sure you have voltage going to the coil. Other than that. Injector or possible lifter collapsed.
Old 12-10-2019, 04:41 AM   #10
Powered1le
Powered1le's Avatar
I did A voltage test on cylinder 7 and it was reading fine.
Old 12-15-2019, 03:45 PM   #11
Powered1le
Powered1le's Avatar
I changed the injector and no change still a misfire. So I removed the valve cover and no physical damage shows.
Old 12-15-2019, 03:52 PM   #12
CamaroBarb
Banned
Drives: cheby Camaro
Check carefully for a cracked valve spring.
CamaroBarb is offline   Reply With Quote
Old 12-15-2019, 04:17 PM   #13
Powered1le
Powered1le's Avatar
Should I remove the springs. There not collapsed.
Old 12-15-2019, 05:41 PM   #14
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot A6
Damn Gremlins!
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
15RS2NV is offline   Reply With Quote
