Old 11-29-2019, 06:23 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Vararam CAI
Just got done reading info on this website. Has anyone put this on their Camaro and have the results that are advertised?
Maroon 6.2L SS is offline   Reply With Quote
Old 11-30-2019, 04:28 AM   #2
Bo White
Bo White's Avatar
Vararam is the most used intakes on the fast list.
Old 11-30-2019, 11:58 AM   #3
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Speaking of which, got any updates to your times, Bo? I know that new build must have put you higher on the fast list
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 11-30-2019, 08:10 PM   #4
Bo White
Bo White's Avatar
I have only been to the track 2 times since CF
Old 11-30-2019, 08:31 PM   #5
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
i have 1 i can't say i could tell it did anything i don't think the but dyno can tell.most CAI's make more intake noise witch tricks you into thinking they are doing more than they actually are but i recommend it. i do like that it is kinda a ram air thing. the stock intake is not bad IMO it get's cold air form behind the headlight.
if you have a choice between
1.CAI
2.cat back
3.tune
4.or in your case DOD delete
what's first?
lemontwist is offline   Reply With Quote
Old 12-03-2019, 06:22 PM   #6
ABM Camaro
ABM Camaro's Avatar
Drives: 2013 ZL1 A6 Camaro
The Vararam is the only true cold air intake system.
The rest breath in engine bay air.
2013 ZL1 Camaro A6. ARH Headers, K&N intake, Tuned by Tampa Tuning
2014
V6 Camaro bolt ons and E85
ABM Camaro is offline   Reply With Quote
Old 12-04-2019, 07:21 PM   #7
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
Mine is the OTR version. I am +3 or 4 degrees over ambient when moving. Heats up while stopped, but immediately drops upon driving. I like mine and it works. Like Bo said, a lot of the fast list people are using Vararam.
More to come.
Black_SS10 is offline   Reply With Quote
Old 12-04-2019, 10:41 PM   #8
Bubblehead
Submarine Pilot
Bubblehead's Avatar
Drives: 2015 Commemorative Edition SS
Vararam was the first upgrade I did and you will notice the power. Get the power wedge with it. Call before you buy, they may give you a deal for buying them together. 😉 Also if you are not going to tune, pull the ECM fuses and let it sit without them for the night. You’ll be all smiles the next day.
All else being stock (the previous owner removed the mufflers - only mod done) The exhaust tone got noticeably deeper.
2015 Commemorative Edition 2SS/RS [L99] -Black-
|GPI: Tune, Rod Mod, PTB; Vararam Intake; ARH 1_7/8 headers & 3" cat-back; GM 3.91 gears; Circle D 4c converter and trans rebuild; Derale trans cooler; B&M deep trans pan; JMS Pedalmax; Taylor Thundervolt 10.4 wires; NGK Ruthenium plugs; 160 tstat|
Bubblehead is offline   Reply With Quote
