Old 12-15-2009, 10:50 AM   #1
Danny Thomas
Danny Thomas's Avatar
Drives: 67 RS, 81 Turbo TA, 2010 ABM 2SS/RS
Send a message via AIM to Danny Thomas
Loudmouth 1 verses straight Pipe
Why would you buy a Loudmouth 1 system or any other brand that was just a straight pipe setup when you can have a muffler shop remove the stock mufflers and run straight pipes. Are there any advantages to the systems. My muffler shop will cut out mufflers and put in pipes for $65.00. Also why not cut out mufflers and install another brand like flowmasters. Looks should still be the same and just have cost of the mufflers without their pipes. Am I missing something here. Also I have 2SS with AFM so there is another issue.
Danny Thomas is offline   Reply With Quote
Old 12-15-2009, 11:12 AM   #2
JuicedSS
JuicedSS's Avatar
Drives: 2010 Camaro 2SS RS M6
You are correct. The LM1 is simply a glorified muffler delete that comes with nicer tips, is made of stainless steel, and can be installed without welding. I had my muffler shop cut the stock mufflers out and weld in stainless pipes for under $100.00. It sounded great until I installed the long tubes. Then it was too loud for my taste.
You could also have aftermarket mufflers, such as flowmasters, welded in and obtain similar sound as a full catback. The only advantage of catbacks is that they are generally lighter than stock, have better flowing pipes (mandrel bends), and replace the factory h-pipe with a better flowing x-pipe. However, a catback has been shown to provide little hp gains over stock. Ultimately, it's a question of cost v. quality/performance- if you want the best possible performance regardless of cost, then a catback is the way to go. I personally was not willing to pay $700+ for negligible performance gains.
2010 Camaro 2SS/RS M6 Black on Black
22" Vossen CV1 Wheels, Roto-Fab CAI, Dynatech 1 7/8" Long Tubes w/ High Flow Cats, Magnaflow Tru-X Pipe,
Barton Short Throw Shifter, Vector Motorsports Tune, Ground Effects, MPD1 Spoiler
JuicedSS is offline   Reply With Quote
Old 12-15-2009, 11:14 AM   #3
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
thread Jack:
JuicedSS - did you get a tune with your LT? If not, did you get a code along with them?
franknbeans is offline   Reply With Quote
Old 12-15-2009, 11:21 AM   #4
JuicedSS
JuicedSS's Avatar
Originally Posted by franknbeans View Post
thread Jack:
I have not tuned the car yet, and am not sure if I will. I did get rear O2 sensor codes. I have reset the ECM twice and the check engine light will stay off for a few hundred miles before coming back on.
Old 12-15-2009, 11:26 AM   #5
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS R6P
Maybe it's because in many states it is technically illegal to drive around without mufflers, at least that's what i've heard. Especially in those states that require yearly inspection, i've heard it can be difficult to pass those inspections with straight pipes. If you bought an aftermarket system, at least you can say you installed some sort of muffler system?!?!?! Just a thought...
blazzin1 is offline   Reply With Quote
Old 12-15-2009, 11:38 AM   #6
I have thought the same thing about this.
Old 12-15-2009, 11:57 AM   #7
linkwpc
The punching cat
linkwpc's Avatar
Drives: '10 Camaro SS Black W/Hugger&W/IOI
If you get the LM1 and plan to get the SLP PowerFlo-X #30220, then you should get the LM1. Thats what I'm planning to do! Its going to sound GOOD!
My car build (COTW 7/23/12) - - - - - - > CLICK HERE! : http://www.camaro5.com/forums/showthread.php?t=80725
linkwpc is offline   Reply With Quote
Old 12-15-2009, 12:14 PM   #8
Danny5
Danny5's Avatar
Drives: 10 2SS, 08 Sienna, 12 Sonic
Can't be that illegal. There have been factory cars that ship without a muffler of any kind. Remember the original SRT4?
It could be that the purpose of your life is to only serve as a warning to others. Ashleigh Brilliant
Danny5 is offline   Reply With Quote
Old 12-15-2009, 02:29 PM   #9
MadMav
Drives: 2010 SS/RS M6
No mufflers on the LM1, so it's not going to help. Plus, you still have to cut off the stock muffs and clamp on the LM1.
Mav
SS/RS M6, SIM, CGM stripes, Barton S/T, BMR trailing arms, ADM Race intake(no scoop), Texas Speed 1 7/8" headers and full 3" exhaust, RMCR custom tune.
MadMav is offline   Reply With Quote
Camaro straight pipe, a quick and easy exhaust mod (videos) 2010 SS RS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 234 12-18-2017 11:06 AM
V6 STRAIGHT PIPE VIDEO's ARE IN!!!!!!!!!!!! derin11 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 70 08-24-2013 11:41 PM
Camaro SS RS Straight Pipe , before and after vid MikeBing Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 120 09-13-2011 11:12 PM
SLP Headers 3in X Pipe and Loudmouth exhust dmaes22 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 02-09-2011 08:40 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 10:03 PM
