Old 12-08-2019, 11:25 PM   #1
bumblebeecamaro
Car Lover By Nature
Drives: 2016 Hyper Blue Metallic SS
Servicing coolant in seven year old SS....
I just bought a 2012 SS that had been sitting for a long time. The engine only has 19K miles. I've already changed the oil but I'm wondering if I should have the coolant system serviced as well?
bumblebeecamaro is offline   Reply With Quote
Old 12-08-2019, 11:57 PM   #2
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
yes and what do you mean have it serviced? i did it myself.
lemontwist is offline   Reply With Quote
Old 12-09-2019, 08:43 PM   #3
FASTDIESEL
FASTDIESEL's Avatar
Drives: 2010 2SS/RS L99 SLP Cosmetics
My 2010 SS has the original coolant (187,878 miles). I know, before the flaming begins, I'm a bad person!
I figure I'll change it the first I have to replace a hose or a water pump.
13.244 @ 104.91 100% stock (#17).
Now - Mike Norris catch can. 245/50/19 Firestone Wingfoot A/S on LT2 black powder coated rims (square). 1 7/8" Speed-Engineering LTH, off road pipes, tune.
Now 12.93 @ 109.13.
FASTDIESEL is offline   Reply With Quote
Old 12-10-2019, 08:47 AM   #4
Avenging Orange
Avenging Orange's Avatar
Just drain radiator and refill.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 12-10-2019, 08:05 PM   #5
mikeman
Banned
Drives: 2015 Camaro
I can only imagine what the inside of your cooling system looks like with that old Dexcool in it. Yikes!
mikeman is offline   Reply With Quote
Old 12-10-2019, 11:40 PM   #6
Black 6.2L SS
Black 6.2L SS's Avatar
Drives: 2014 1SS/RS, LS3, NPP
$15 for Dexcool concentrate at my local Chevy dealer and 2 gallons of distilled water. Just drain the radiator and refill. The siphoning action also pulled quite a bit out of my block and overflow tank as well. It was super easy.
Black 6.2L SS is offline   Reply With Quote
Old 12-11-2019, 12:09 PM   #7
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
As a mechanic I never change coolant on any of my cars unless I'm fixing a leak! You'll be fine as clearly indicated by the high mileage
TommyTheCat is offline   Reply With Quote
Old 12-11-2019, 09:14 PM   #8
lemontwist
lemontwist's Avatar
walmart 2 gal of prestone "dexcool" 24 bucks 2 gal of distilled water 1.75 so at 25.75 i considered it cheap insurance but i also did the heater core so she was about a .5 gal low.
