![]() Drives: 2010 Camaro 2SS Join Date: Mar 2018
Vibration at higher speeds
Alright so I was trying to avoid making this thread but after having my wheels balanced for the 3rd time and still having vibrations im out of ideas. I got new wheels mounted on my car a month ago and have had them road forced balanced by discount tire 3 times due to a bad vibration at 55+ mph. The wheels are Sothis wheels Sc005 20x10 +25 all the way around on nitto motivo 275/315 setup. After the 3rd time balancing and after installing hubcentric rings i still have vibration. The tires have about 25k miles on them but still have decent life left. Im just wondering if I should go somewhere else to get them balanced or if I should look at getting new tires as the gentleman at discount tire suggested. Any input is appreciated!
#2 | |
SEAHAWKS FOR LIFE!!
SEAHAWKS FOR LIFE!!
SEAHAWKS FOR LIFE!!
this is what they rec..dont mind the kahoot
#6 |
Yeah I might have to look into the axle lubing just in case. Getting into those higher miles! Im pretty positive though its a wheel/tire balance issue due to it starting to happen after I got new wheels. My front wheels also shake.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
If the wheel is shaking it's likely a tire issue. There may be a broken belt in the tire or ply separation.
#8 |
376 cubic inches of fun
Road force balance is not gonna compensate for crappy Chinese wheels.
#9 | |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Lift the front end, shake the wheels. Look for loose areas.
Here was my issue. Your situation is similar. |
#10 |
![]() Drives: 2011 RS Join Date: Jun 2018
U say "here was my issue"...then Not A Damn Thing Shown!
Proud Owner Of '11 Camaro
#11 |
#12 |
#13 |
Spec I have followed your issue and have yet to do jack it up and see if it is my own. I was originally thinking it was the wheels and still am but the guy at discount tire said someone came in with high end wheels and had the same issue. Said the guy just eventually just bought new tires.
#14 | |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
