Old 12-15-2019, 03:44 PM   #1
Ammo_Don
Ammo_Don's Avatar
Drives: 15 1SS 1LE
6 speed trans fluid
Just want to make sure I can for sure no doubt use this in my 1LE before I change it out today.
Ammo_Don is offline   Reply With Quote
Old 12-15-2019, 03:59 PM   #2
G8One2
Drives: 2014 Camaro 2SS
Not sure about that stuff. I know the stock GM fluid is actually an ATF
G8One2 is offline   Reply With Quote
Old 12-15-2019, 04:35 PM   #3
Ammo_Don
Ammo_Don's Avatar
Drives: 15 1SS 1LE
Says it's formulated for ATF. I got it on a recommendation from these forums I just need reassurance from other who have used it previously.
Old 12-15-2019, 07:46 PM   #4
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
Wait for more replies but if I remember correctly there are other members who have used this product and it’s perfectly fine and recommend.
HOJO is offline   Reply With Quote
Old 12-15-2019, 08:25 PM   #5
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
i run this and it works good for me.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
lemontwist is offline   Reply With Quote
Old 12-15-2019, 09:00 PM   #6
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
I used it for over a year , switched to red line d4 atf now. No difference in shifting between the two, both are great in the tr6060
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 12-16-2019, 03:46 PM   #7
Black 6.2L SS
Black 6.2L SS's Avatar
Drives: 2014 1SS/RS, LS3, NPP
I buy the OE bottle and LSD additive from the dealer.
Black 6.2L SS is offline   Reply With Quote
Old 12-16-2019, 05:39 PM   #8
zlathim
zlathim's Avatar
Drives: 2010 Camaro 2SS/RS M6
It looks like the correct fluid to me.
GPI SS2; EE E2 catch can; SP 1 7/8" LT Headers w/ hfc; FM AT 3" cat-back; CAI Cold Air Intake; AEM Wideband
Tuned by GPI
McCleod RXT; MGW flat stick; Ram Clutch slave cylinder & hydraulic adjuster
BMR cradle & diff bushings, trailing arms, toe rods & upper control arm bushings
Hotchkis sub-frame brace
Stop Tech Z-23 brakes
4.10 gears, Eaton Truetrac, LPW diff cover
Best 1/4 mile 12.073 @ 115.68 mph 3,300 ft DA
zlathim is offline   Reply With Quote
Old 12-22-2019, 11:11 AM   #9
Ammo_Don
Ammo_Don's Avatar
Drives: 15 1SS 1LE
I finally got around to changing the transmission fluid. I did the transmission fluid and diff fluid at the same time.
I really didn't think changing the fluid would change the clunky shifting of the car but wow. It feels completely different now. The OE fluid was still good and red but it doesn't compare to aftermarket fluid. Anyway, just my observations. 20k miles on car
Old 12-22-2019, 12:08 PM   #10
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I've got RP in mine, as well. I think it is better than stock in my experience.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is online now   Reply With Quote
Old 12-23-2019, 03:11 AM   #11
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Been running RP for many years in all three and no issues what so ever.
Orange Krush II
Old 12-23-2019, 09:05 PM   #12
lemontwist
lemontwist's Avatar
i did both also with around 20k on my car unless the PO changed the trans fluid i didn't notice any change. i kept seeing people claiming big changes but i saw/felt none....
Old 12-23-2019, 11:05 PM   #13
Vegas Bound
Drives: 2013 Sparkly Red One
You use LSD additive in your trans?
Vegas Bound is offline   Reply With Quote
Old 12-23-2019, 11:35 PM   #14
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
I switched to Redline ATF (better) from OEM (20k miles). Swapped back to OEM (worse) (4k miles). Switched again to Redline ATF (better again) (8k miles). Better shifting 1-2 and the rest of the gears. RP is also good stuff.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
