Old 12-16-2019, 04:54 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Front tire size options
Anybody run front tires that are a little shorter than the rear tires? (within 3/4" say) I read a post somewhere on the internet that had mentioned that you want to keep your front tires the same height as your rears or a little taller for best weight transfer. Can you guys give me some examples of your setups and if there are advantages/dis-advantages to the various front tire differences? I swear in sportsmans class I've seen some cars with shorter front tires.
Maroon 6.2L SS is offline   Reply With Quote
Old 12-16-2019, 05:36 PM   #2
G8One2
Drives: 2014 Camaro 2SS
The difference in tire diameter needs to be 5% or less. Anymore than that, your ABS and traction control will fault out, and not work. Your speedometer and odometer will be off also. I dont know about for track use, if that matters or not.
G8One2 is offline   Reply With Quote
