Old 12-18-2019, 08:42 PM   #1
The Wanderer
Drives: Blaze Red 2014 2SS/RS
Will the stock fuel pump on a 2014 l99 ss
support 575 -615 h.p. with a whipple super charger and motor has a cam? probably be running about 8 lbs of boost.
The Wanderer is offline   Reply With Quote
Old 12-19-2019, 07:49 AM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
A stock pump with a boost a pump might but it will be right on the edge I believe. I would just do a ZL1 pump they are about $300. ZL1 pump with a booster can handle about 700-750WHP
Greenhornet2 is offline   Reply With Quote
Old 12-19-2019, 09:41 AM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
I can not recommend it, even with a voltage booster.
Our JRE FSCM is a drop in for 199.00 and controls a ZL-1 drop in pump correctly which we also carry, this will support 650 RWHP.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 12-19-2019, 11:02 AM   #4
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
I had the same question.
So...........
I went with a fore innovation triple pump
My primary pump is a Walbro GSS 342
and my secondary pumps are TI F90000267
I have them staged and only works when I hit over 2lbs of boost
I know you can do that with a dual but I was told it will load manage between both pumps to distribute fuel.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 12-19-2019, 12:49 PM   #5
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
Don't skimp on fueling!!!!!!! At minimum, go ZL1 fuel pump.
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 12-20-2019, 06:21 AM   #6
eLeSthree
Drives: 2011 Camaro SS 6sp
Nah, do it the hard way, like everyone else. Get a ZL1 pump, 6 months later add a bap, then 6 months later add an aux kit, then 6 months later sell it all and get what you should have bought in the first place. A dual or triple fuel system. Otherwise I'll feel left out.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 12-20-2019, 07:27 AM   #7
rgrmoreira13
Now I feel left out LMAO
I didn't do any of that.
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 12-20-2019, 09:17 AM   #8
Greenhornet2
We either lol. But I also don't plan to go over 750WHP... At least until I blow it up.
Some people are happy with 600 and stay there.
Old 12-20-2019, 10:39 AM   #9
rgrmoreira13
I WAS ok with what I was making (702rwhp 600tq on 7lbs of boost) but now I want to make around 10lbs of boost so I want to hopefully make at least 720rwhp
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
Old 12-20-2019, 10:56 AM   #10
dreksnot
dreksnot's Avatar
Bahahahahaha! Ask to get LPE twin with ID850, talked into ID1000 by installer, get BAP for safety ONLY, then tune with BAP for more fuel for power, order Fore Double and ID1300, ponder what I just did, change order to Fore Triple and ID1700. I thought that was the regular mental route???
Old 12-24-2019, 10:22 AM   #11
UNRIVALED SS
UNRIVALED SS's Avatar
Drives: 2010 Camaro SS
Send a message via Yahoo to UNRIVALED SS
Perfect
Quote of the year !
This keeps all the vendors happy also.
UNRIVALED SS is offline   Reply With Quote
Old 12-24-2019, 10:33 AM   #12
Greenhornet2
I would guess you'll get closer to 740WHP as long as the fuel system can keep up. Our cars get about 20HP per/lb. General rule is 5-6% per lb from it's NA horsepower on a supercharger. about 7% from a turbo. 426base HP 5% 21.3HP. These aren't absolute, but a decent idea.
Old 12-24-2019, 10:44 AM   #13
Juiced1
Drives: 2012 2SS CAMARO 45th
I would just jump right in and get an DSX auxiliary pump or our dual in tank pump. They'll handle what ever you can throw at the stock short block. A ZL1 pump paired with a voltage booster or fpcm of some sort would get the job done but if you want to run E85 or add more boost down the road you'd be upgrading again like mentioned above.
Juiced1 is offline   Reply With Quote
Old 12-24-2019, 01:53 PM   #14
rgrmoreira13
It better lol
With a triple pump I should have enough fuel for a whatever the D1x can throw at me. I know that the 1050x will not hold up however. I should have gotten the biggest injectors to begin with like the ID1700s so I guess I will have to save for them and get a smaller pulley. I don't think I am going to go anymore than 10lbs of boost because I don't want to damage anything on the rear end or in the engine as it not forged. (Next phase in the car along with bigger heads and maybe with a built transmission.)
Specs
ID1050x Injectors
Flex Fuel Sensor
NW 103mm Boosted TB
