Old 12-20-2019, 01:03 AM   #1
Moreno1
Drives: G5.R
Gauging interest... Moreno Camber/Caster Plates
How many people want these? Considering bringing them back, but it's difficult to determine the demand.
If your interested, please post up
Moreno1 is offline   Reply With Quote
Old 12-20-2019, 01:26 AM   #2
newz1
Drives: 2013 CHEVROLET ZL1
New camber plates.
I would be interested.
newz1 is offline   Reply With Quote
Old 12-20-2019, 07:22 AM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
I would be interested in a set for a set of Bilstien B6’s. But gotta wait awhile to pay for heads an lifters.
Orange Krush II
olblue75 is online now   Reply With Quote
Old 12-30-2019, 07:42 AM   #4
CamaroEMC
Drives: 2010 Camaro 2SS/RS
I was intrested, but settled with Ground Control because they were the most similar that was available. Now they don't fit and I am pretty annoyed by it.
2010 Camaro 2SS/RS
BMR Subframe connectors
BMR front and rear swaybars
BMR SPrings with Koni V2 shocks
TSP Cam build tuned to 482 rwhp
CamaroEMC is offline   Reply With Quote
Old 01-09-2020, 04:00 PM   #5
jksynergy
jksynergy's Avatar
Drives: 11 SW SYNERGY SERIES/14 1SS 1LE
Interested. Running Viking coilovers and truly could use a set.
Sent from my SM-T377T using Tapatalk
2011 Summit White Synergy Series Edition, the hot innocent woman named Ava that we show off around town, dressed in white complete with angel's wings. Sold, but never forgotten.
2014 1SS 1LE. Bama, sporting Red Rock Metallic demon's horns, when we are ready to get naughty and open a can of whoopass! Airaid, Spectre, Xpel,Bowler shifter Peddars, UMI, Ult Perf. Diode Dynamics, JRE Tune, XS Power battery,
Hooker Headers Blackheart exhaust,Powerbrake
InstaGram & Twitter: @jlouie62
FB: hangtimeracing
jksynergy is offline   Reply With Quote
Old 04-27-2020, 10:10 PM   #6
Scotty D
Drives: 2014 1le 1SS CRMT
I have the first series camber plates
I am looking for instructions to install them if anybody could help me out thank you
Scotty D is offline   Reply With Quote
Old 04-28-2020, 07:12 AM   #7
hesster
hesster's Avatar
Drives: '10 T/A Conv, '10 2SS, '77 SE T/A
Great way to get precision alignment specs for Camber and Caster. This of course requires a Alignment Tech willing to spend the time to dial it in, which is some trial and error. Mine are on BC Coil Overs, (1st Pic), installed on car pre-adjusted (2nd Pic), and finally as adjusted to get alignment specs desired (3rd Pic). Camber/Caster is obtained by rotating the base and lock down fastener positions. Be careful to not over torque the lock down socket head bolts as they can break.
hesster is online now   Reply With Quote
Old 05-08-2020, 02:09 PM   #8
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
Interested. I currently have the Vorschlags. Very nice and zero noise but with OE springs, you can only swing 1 degree. If you go max, the spring hits the inside of the strut tower. And you can't turn them to work in more castor. The Morenos were nice as they offered more than 1 degree of spread, and could be turned for more castor.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is offline   Reply With Quote
Old 05-21-2020, 10:49 PM   #9
VOIT
VOIT's Avatar
Drives: Z/28
Interested.
VOIT is offline   Reply With Quote
Old 06-01-2020, 01:50 AM   #10
Tyrfryr
Drives: 2010 2SS Camaro, ‘18 Sierra Denali
Interested, when do I buy?
Tyrfryr is offline   Reply With Quote
Old 06-09-2020, 01:58 AM   #11
kidreno_21
kidreno_21's Avatar
Drives: Zr2 Blazer, 2013 ZL1 Black on black
I am interested. Do they work with the factory ZL1 struts?
kidreno_21 is offline   Reply With Quote
Old 05-10-2021, 02:13 PM   #12
Airmaster
Go Gators!
Airmaster's Avatar
Drives: Camaro Jeep Abarth 944 325i
Interested.
'13 Camaro, '97 Wrangler, '12 500 Abarth, '85.5 944, '06 325i
Suspension Mods: BMR and JPSS Sways, BMR Poly Bushings, BMR strut tower brace, BMR control arms, BMR toe arms, stock springs and struts
Engine Mods: All bolt ons (haha)
Brake Mods: Brembo SS caliper swap front and rear
Airmaster is offline   Reply With Quote
