Old 12-20-2019, 01:53 PM   #1
JGermain15
Drives: Red 2014 2LS Camaro
2014 v6 ABS Issue?
I pulled up to a red light, nothing but a routine stop, didn't slam on the brakes or anything. I got a "StabiliTrack Sevice" notification and a bunch of lights on my dash. I pulled over and restarted my car and noticed when my car is off, the ABS has an odd droning sound. It vibrates and makes a sound that can be heard from inside and outside the car. Scanned it and came out with a code for the pump motor. We tried resetting it manually and electronically, no luck. Looks like I'll have to replace the pump but I figured I'd come on here first. All sensors, wires and connections are good.
I took out the fuse so it doesnt drain my battery. Has anyone had this problem?
JGermain15 is offline   Reply With Quote
2014 camaro v6, abs, abs pump, service stabilitrack
