12-20-2019, 11:56 PM | #1 |
Drives: 1997 30th conv & 2012 45th conv Join Date: Jul 2017
LS3 removal Camaro 2012
I hope someone can help me with a step-by-step guide how to remove my LS3 and seperate engine from automatic transmission. I need to get the engine out for restoration. I got the service manual but can't find any step-by-step guide or on google.
12-21-2019, 12:26 AM | #2 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Disconnect battery, drop exhaust, drop driveshaft, tie back AC compressor, disconnect top of front struts, tie back front calipers, split main fuse box, drain coolant, disconnect coolant lines, drop entire front cradle, 6 bolts, with engine and trans in place. Hopefully you have a lift, much easier that way.
I might be missing a couple small steps. |
12-21-2019, 07:34 AM | #3 |
Drives: 2014 Camaro 2SS Join Date: Feb 2015
If your dropping it from the bottom, theres no need to disconnect the struts or the brakes. Idk why people do that. Making more work for themselves. Just disconnect the balljoints from the hubs. Leave the brakes and the struts alone. Drop it that way. Out the bottom isnt really necessary either. It will come out the top if you dont have the means to get the car high enough to drop it from the bottom.
12-21-2019, 09:07 AM | #4 |
There are at least 2 ways to skin a cat.
12-21-2019, 10:49 AM | #5 |
I was thinking to remove from the top.
12-21-2019, 12:19 PM | #6 |
If you pull it from the top, you may need to remove the front fascia if the boom on your cherry picker wont reach. You can leave the core support. Just remove the upper and lower radiator hoses and the heater hoses. Unbolt the ac compressor and the power steering pump if you have one, rest it aside. Take the whole engine /trans harness with the engine when you pull it. Make your life easier when putting it back together. Unplug it from the ECM and disconnect it from the fuse box.
12-21-2019, 05:59 PM | #7 |
I removed from the top. As long as you have jack stands, ramps, hoist you should be good. Just make sure to properly support the transmission. Also, I would highly suggest you remove the front bumper cover. You will be hard pressed for hoist clearance if you don't.
IDK what happened, but when I did my recent swap I lost all my freon. Tied my compressor back to the passenger side and didn't touch it after that until reinstall of the LS3. After install was complete, tried my AC...nothing. Ran a pressure test and it was completely empty. Tried a refill. Was nice and cool until about an hour later. I could see the freon leaked out near the main 2 lines fitting. I guess it somehow loosened or the seal got messed up when it was moved. I was very careful with it. Sorry for the thread derail. Just saying to be careful when you are moving that compressor around.
12-21-2019, 09:54 PM | #8 |
Started#gottalovethatblue
Since others have basically answered your question, you know that if you have a car with an automatic from the factory you have a L99 and not a LS3, right?
12-22-2019, 12:48 PM | #9 |
Update: L99 not LS3
Thank you for correct me about engine. Yes, It's an automatic and a L99 not LS3. New on 5 gen I thought all SS had LS3, but as you wrote, automatic have L99.
The basic difference between the L99 and LS3 motors is that each one was built for a specific type of transmission. The more powerful LS3 engine is paired with Camaro SS models that feature the manual transmission. Likewise, the L99 comes from the factory in automatic Camaro SS automobiles. The L99 is a 400-horsepower engine while its fraternal twin--LS3--is rated at 422 hp. The difference lies in the valvetrain; as the short-block, heads, and intake manifold are identical. One small note is that the L99 does have slightly less compression than the LS3. BTW Nice car and good looking mods you have done on your Camaro, Pyroguy! |
12-22-2019, 02:24 PM | #10 |
Some people get a hard on about the LS3 L99 thing.
12-23-2019, 08:23 PM | #11 | |
Good luck with your engine project!
12-23-2019, 08:35 PM | #12 | |
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
don't the L99 have afm that sucks or something like that |
12-23-2019, 09:38 PM | #13 |
Drives: 2010 SS/RS M6 BIG cam Join Date: Mar 2016
Biggest difference is cam shaft and valves in the heads, with slight changes in compression
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
12-23-2019, 09:39 PM | #14 |
Cars with the L99 is faster in the quarter that LS3...... that ought to stir things up a bit.
