Old 12-25-2019, 10:55 PM   #1
Willyow
Willyow's Avatar
Drives: 13 zl1
15in vs 17in tire
I’m finishing up my 13 zl1 build and am curious of any actual proven results between a 17in rear vs a 15 in ? My car has a 15 conversion already but I currently have a 17x10 rear wheel with m/t 28/11.50/17 et street r bias ply tire .. and of course if I decide to buy wheels I’ll be going with a 275/60/15 radial pro ...my car should 60ft in the 1.37-1.42 area ...don’t mind spending the money on the 15 in setup but before spend the money I’d like to know actual real results you’ve had switching..
Willyow is offline   Reply With Quote
Old 01-02-2020, 12:56 PM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I haven't done it. If I were to think about I would only consider it if I were having problems with traction with 17's then I would consider the 15's if I was all out drag car, which I am not. More sidewall more shock absorbed especially on an M6 car. If you are hooking on the 17's, why switch? I have no real results though. I am curious to see what others have to say.
Greenhornet2 is offline   Reply With Quote
Old 01-02-2020, 05:33 PM   #3
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
I looked up the weights on Jegs website so I could compare, and heres what I found:
17" Weld wheel (25 lbs)
28x11.5 ET Street bias ply (27 lbs)
=52 lbs
And
15" Weld wheel (14 lbs)
275/60R15 ET Street Pro (31 lbs)
=45 lbs
7 lbs a piece less, so a 14 lb reduction of rotational weight, not to mention you need smaller brakes and have lightweight options like Aerospace, equating to more reduction in rotational weight. If you're like me, I want every thousandth of a second in the 1/4. Hopefully someone has some experience/input on the difference.
Annoyingly enough, Amazon has the 15" listed at 21 lbs. I wish it were a bit easier to get this info, other than contacting Weld directly. If I owned both of them, I would make a thread with pictures of the scale and back to back timeslips so the info could be readily available.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
