![]() Drives: 2010 Camaro 2SS/RS Join Date: Apr 2018
Ground Control camber plate issue
Has anyone here installed camber plates from ground control on koni v2/BMR lowering spring setup?
I am having some issues with fitment, namely the spring perch from Ground Control not fitting correctly.
2010 Camaro 2SS/RS
BMR Subframe connectors BMR front and rear swaybars BMR SPrings with Koni V2 shocks TSP Cam build tuned to 482 rwhp |
![]() ![]() Drives: 02 Camaro B4C Join Date: Nov 2016
I haven't had those issues, I'm running stock springs & struts.
However I am not happy with the Ground Control cast camber plates. When I received them instructions were not included. I had a bolt hole strip out. Prior to going to the track in November I could not adjust the camber. The plates seem to be frozen together. Over all not the experience I was expecting. I would not buy them again nor would I recommend them.
A man's garage is his castle
1969 Camaro SS 1970 Camaro SS 2002 Camaro B4C 2014 Camaro SS Dedicated Track Car 2015 Camaro 1SS 1LE 2008 HHR SS 1996 Silverado Crew Cab Long Bed Dual Rear Wheel |
Specifically, the part that should press into the stock spring perch/sound isolator is like 2mm too wide in diameter. Any ideas?
2010 Camaro 2SS/RS
![]() Drives: 2014 2SS 1LE,RS,NPP,Recaros in SW Join Date: Apr 2012
