12-31-2019, 02:24 PM | #1 |
SS Camaro what kind of gas y’all putting?
is 87 still good to use in a 2014 ss or would 89 be better?
12-31-2019, 02:29 PM | #2 |
Drives: ABM #93 Join Date: Oct 2018
Premium only if you want it to run on the performance table in the ecm. Run all the lower octane fuel out of it and Put premium back in it, then do the fuse pull and you’ll see what I mean.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
12-31-2019, 03:05 PM | #3 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
93 only...js
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
12-31-2019, 03:09 PM | #4 |
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
Or 91 in those places that do not have 93. Here's how to get your car back up to par after using low octane fuel (SS trims). Empty out the tank to E as close as you can. Refill about half a tank with Higher Octane (91 or 93). Let THAT run down as close to E as you can. Refill the tank with Higher Octane again. Park your car for the night and pull the 5 and 20 fuses from your under-hood fuse box and keep them off for at least 6hrs. Reinstall the fuses and stay off the low octane gas in the future. Just fyi too... due to most fuel stations having one pump with multiple octanes, I'd recommend the 'fuse pull' at the very least after every other oil change. As for what fuel I stick to, for the most part... I stick to Chevron w/ Techron... or Shell or Conoco 76... |
12-31-2019, 03:18 PM | #5 |
damn i never knew any of this. i thought it was good just to use 87 on my car. i will do this. right now i am on E so i will put 93 starting friday when i put gas in my car. my car isn’t a daily driver either.
12-31-2019, 03:19 PM | #6 |
And fyi only buy from top tier gas stations. Shell or Sunoco are the best in my area. Sam's Club gas is terrible for performance cars...
12-31-2019, 03:21 PM | #7 | |
12-31-2019, 03:22 PM | #8 |
i only use Exxon gas in my car which is 87
12-31-2019, 03:28 PM | #9 |
Shell 93 here.
12-31-2019, 03:30 PM | #10 | |
You need to keep them off overnight (min 6hrs). Also, couldn't hurt but I wouldn't do them after EVERY oil change... just something to keep in mind. Dirty gas is out there even using top tier gas... and these uni-pumps using multiple octanes... we surely get a nice gulp of low octane fuel before the high octane fuel kicks through. The car will feel lighter on its feet once you get this done. |
12-31-2019, 04:42 PM | #11 |
Drives: SUMMIT WHITE 2SS/RS CAMARO Join Date: Feb 2008
Just filled up with Shell 93 AM today at $3.09 here in So West Florida.
What are you California guys paying ?
12-31-2019, 04:57 PM | #12 |
Drives: 2014 1SS/RS, LS3, NPP Join Date: Feb 2019
93 octane in mine.
12-31-2019, 05:23 PM | #13 |
i am glad i did ask because i really didn’t know this
12-31-2019, 05:35 PM | #14 |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Should we be concerned with the fuels alcohol content in regards to parts longevity? My ol' school carburetors hate the 10(or so)% ethanol of current fuel. ALSO is there any type of fuel filter installed on these vehicles? I have a '15 2LS and a Z/28. Trying to learn all I can about the high tech machinery.
