BOHIC
Drives: 2010 Camaro SS "Enola" Join Date: Jun 2014
Next round of mods to get to 1000whp
Time for the next round of mods. Car is mostly driven on the street with the occasional trip to the strip and planning on going to Camarofest again and eventually FL2K and TX2K. Looking at a 427 resleeve from Texas speed with a Novi 2200x from ECS, custom radiator/fan combo from Dewitt's, rpm transmission transbrake for my 4L80E and maybe a bumpbox, an ngauge, and nitrous for special occasions.
Just need to figure out a few more things and would like some y'all's input. What intake manifold? should I go with an electric water pump? What else should I add ![]() Here's the link to my garage to show what I have so far. https://www.camaro5.com/forums/camar...=view&id=19390
What else can I do to my Camaro?
USA-1
Not sure exactly on what to recommend for the manifold, but not sure if you've seen this. https://gwatneyperformance.com/the-u...dyno-shootout/
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
#3 | |
BOHIC
Drives: 14 Camaro SS 1LE Join Date: Feb 2019
That looks like a solid build, the blower is more than capable. Ultimately the valvetrain will make the difference in both driveability, performance, and longevity at those power levels.
BOHIC
That's why I've reached out to a few builders to get their input. Trying to have this done in time for Camarofest this year.
