01-07-2020, 09:01 AM | #1 |
Drives: 2019 ZL1 Join Date: Oct 2019
Fuse pull, will it make your car explode?
The fuse pull. Let's discuss just that. Sorry the other stuff was irrelevant here I think.
01-07-2020, 09:03 AM | #2 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
for the below, just take the fuse out and no CEL at all
Exhaust - Unplug the NPP valves in the rear, cover the connectors (male and female) with electrical tape and zip tie them up. There will be no CEL (soft code only for NPP valve not functioning, but no light). Results are a nice tone with little to no drone at all at all times and more pops and gurgles throughout the rev range. Very good sounding. Also noticed a very nice throttle response gain at part throttle in all modes, no change at WOT for power/etc though. If you look at the inside of the NPP mufflers (pics online) for 17+ you can see that when the valves are closed, there is an extremely convoluted and poorly flowing pathway for the exhaust which likely is what causes the throttle response drop, as compared to an open valve. You can always plug them back in from time to time to avoid "sticking" for the valves. Do not unplug the fuse 51 or you are likely to have erratic issues and CEL codes fyi (unlike previous gen ZL1's where this worked fine I think).
2019 Crush A10
E-Force 2650 670WHP 615WTQ All besides the 2650 is bone stock down to the air filter. |
01-07-2020, 09:07 AM | #3 | |
01-07-2020, 09:12 AM | #4 | |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
01-07-2020, 09:12 AM | #5 |
01-07-2020, 09:43 AM | #6 |
Mine was pulled with stock exhaust for months, no issues. It is free and quick and easily reversible, those connectors are kind of a pain to get at.
2019 Crush A10
01-07-2020, 11:30 AM | #7 | |
Drives: 18 zl1 Join Date: Aug 2017
I concur. fuse pulled on 2017 for years with no issues, automatic trans. almost 5 months on current 2018 zl1 with fuse pulled, also automatic, no issues. This is actually the first I've heard of someone having cel's with a npp fuse pull, ever. |
01-07-2020, 12:08 PM | #8 |
Drives: 2018 ZL1 Join Date: Oct 2019
No need to pull the fuse. Just go to infotainment and set the exhaust to track. It will keep them open all the time.
2018 ZL1 A10 - Rotofab Intake, LT5 TB, TSP Headers, ATI Balancer, 9.1 Lower Pulley, JMS BAP, Flex Fuel.
01-07-2020, 12:10 PM | #9 |
01-07-2020, 12:12 PM | #10 |
I havent noticed that. Same sound for me with the fuse pulled. Although I have headers and its loud any way
01-07-2020, 12:14 PM | #11 | |
There is a difference. If you rig up a switch to remotely "pull the fuse", you'll notice the difference. Especially if it's once the muffler gets some heat into it. |
01-07-2020, 12:25 PM | #12 |
It closes at part throttle and cruising. Very noticeable once you get an aftermarket exhaust. Fuse pull keeps it open all the time.
2019 Crush A10
01-07-2020, 01:12 PM | #13 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
I pulled out the fuse for about a month and noticed my blind spot thing in the mirror didn't work. I put three fuse back in and it still doesn't work.
Honestly im glad it's not there anymore..... |
01-07-2020, 03:26 PM | #14 |
Drives: 2019 Chevy Camaro ZL1 Join Date: Mar 2019
Sorry for the rookie question. Based on OP's post, keeping the valves open will produce more crackles and gurgles. Is this true? I love this car but the one thing I miss is the constant gurgling I used to get from my Chevy SS even with regular neighborhood driving.
