Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Miscellaneous Items
Old 01-08-2020, 10:33 AM   #1
PFYC
PFYC's Avatar
Drives: Yes
January Sale - Whats HOT Whats NEW @ PFYC!
NEW!! - LED Switched Under Hood Lighting Kit for 2010-2015 Camaro
https://www.pfyc.com/led-switched-un...15-camaro.html
Add some new lights to your 5th Generation Camaro by adding the LED Switched Under Hood Lighting Kit for 2010-2015 Camaro. Our LED kit for lighting up the door sill plate on your 2010-2015 is designed as an option to add to our LED interior w/dome lighting kit. Each kit comes with 2 x 24" BRIGHT or SUPERBRIGHT self-adhesive LED. strips to cover both doors sills. Each strip has 36 LEDs. If you order these in conjunction with our LED. Interior Lighting W/Dome Kit, the footwell kit will have extra leads to connect the door sill LED's to make installation a very easy addition. If not you will need to follow the interior kit wiring instructions. These will operate just as the interior lights do retain the "theater" effect and come on when you open the doors or turn on the interior lights. Really sets your interior apart from all the other Camaro's out there. Orange and Aqua colors can only be ordered in Superbright.
Application
2010 2011 2012 2013 2014 2015 Chevrolet Camaro
Use coupon code SAVESIX at checkout and save!!
NEW!! - Pedal Commander Throttle Response Controller for 2010-2015 Camaro
https://www.pfyc.com/pedal-commander...15-camaro.html
Get the power of your Camaro the moment you press the pedal to the floor by adding the Pedal Commander Throttle Response Controller for 2010-2015 Camaro Eliminates Delay. Nowadays, vehicles are notorious for their delayed throttle response. That's where the Pedal Commander comes in. These days, vehicles use a drive-by-wire system that monitors the position of the gas pedal to control the throttle electronically, similar to a dimmer switch. The problem with this setup is that the signal from the pedal has to first be sent the ECU, which in turn then sends the signal to the actuator motor that controls the throttle body itself. This delay is most noticeable when trying to speed up to merge with fast moving traffic or pass a slower moving car. However, the Pedal Commander Bluetooth Throttle Response Controller will eliminate that delayed throttled response, giving your vehicle a drastic night and day difference in performance. Four Adjustable Control Modes. Unlike other throttle control devices that are either on or off, the Pedal Commander comes with 4 control modes: Eco, City, Sport and Sport +. Best of all, each mode has an additional 8 different levels of sensitivity which allows you to personally adjust each mode to your own personal driving style and needs. Switching between modes can be done manually on the Commander or can also be done using your smartphone (Pedal Commander App), without having to bend over and physically touch the Pedal Commander. Compatible with Aftermarket Programmers. The Pedal Commander can be used in conjunction with common aftermarket OBD-II programmers and/or monitors such as: SCT, Diablosport, Hypertech, Superchips, Bully Dog, and Edge. 2-Year Product Warranty. Pedal Commander manufactures their Bluetooth Throttle Response Controller to the highest quality and standards with CE and TUV Certification. However in the event you do receive a defective or malfunctioning device, Pedal Commander will replace it free of charge within 2 years of the original purchase date. Easy Plug & Play Installation. The Pedal Commander Throttle Response Controller connects directly into the stock throttle position sensor found on the drive-by-wire gas pedal using an OEM style plug and play connector with no permanent modifications required. The Pedal Commander is 100% reversible making it warranty friendly.
Application
2010 2011 2012 2013 2014 2015 Camaro
FREE SHIPPING in the Lower 48 states! Half price shipping to Canada.
Vararam VR-DRX Air Intake System for 2012-2015 Camaro V8
https://www.pfyc.com/CAVR-DRX.html
The Long anticipated VR-DRX Ram Air Induction System
When is comes to horsepower gains the air intake is usually the cheapest bang for the buck. You Camaro will love the fresh cold airflow provided by this VR-DRX Ram Air Induction System.
For 2012-2015 V-8 & ZL-1 Camaro's Born out of the VR Race' & COPO' programs '
On Road Testing on a stock 2012 V-8 LS-3 Automatic Camaro: For the stock times we chose the Best' out of 5 runs. With the VR system we chose the Slowest' time out of 5 runs.
We Data log using EFI live to verify changes in MAP Pressure, MAF flow rates, Timing curves and Air fuel ratio etc. This Kit has over 700 Log files in 2 yrs ranging from 100 mile cruises to ΒΌ mile passes
We guarantee either a 3 tenth or a 3 MPH improvement in the ΒΌ mile with this system or we will take it back and pay shipping both ways!' That is the VARARAM way!
Application
2010 2011 2012 2013 2014 2015 Camaro V8
Roto-Fab Cold Air Intake System for 2010-2015 Camaro SS 6.2L V8
https://www.pfyc.com/CA3005.html
Roto-fab's 5th generation Camaro cold air intake (also known as a CAI or cold air induction) for your V8 equipped Camaro is one of the highest quality, most well designed intakes on the market. The Air Box is custom made to keep engine and radiator heat away from your filter. The molded air box adapter tube incorporates the MAF (mass air flow) sensor and has a large, 6" filter mounting flange. The Inlet elbow is available in cross link poly (plastic), carbon fiber look, or polished stainless steel. The high quality silicone hoses are available in a variety of colors. The intake system installs easily using factory mounting points and doesn't set any check engine codes. No tuning is required. Both oil and dry filters are available, but our oiled filter is one inch longer than the dry filter and has an open ended "inverted cone" shape to give you maximum performance.
Application
2010 2011 2012 2013 2014 2015 Camaro SS 6.2L V8
Borla 11775 S-Type Axle-Back Exhaust 2010-2013 Camaro V8
https://www.pfyc.com/CA5032.html
BORLA Cat-Back exhausts feature patented, straight-through and multi-core technology to unleash hidden horsepower. Increased exhaust velocity adds power, driving excitement, fuel economy and the distinctive BORLA Sound of Power respected by motoring enthusiasts everywhere. Each system is built from premium austenitic stainless steel, superior to T-400 series knockoffs, to give you the absolute best in performance and durability. Ultra-smooth mandrel bends ensure maximum flow and power, and precision computer-controlled CNC manufacturing ensures an accurate fit. Best of all, BORLA stands behind every system with a Million-Mile Warranty. Just what you'd expect from the world's most experienced (and most winning) exhaust brand.
Application
2010 2011 2012 2013 Camaro SS 6.2L V8
Stainless Fuel Rail Covers for 2010-2015 Camaro SS
https://www.pfyc.com/CA3009.html
Dress up your fuel rail covers with these easy, snap-on stainless steel fuel rail covers designed to snap over your factory fuel rails. Sold as a set of two (2).
Crafted from 304 stainless steel.
Will never tarnish or change color.
Built to endure high engine heat.
Application
FREE SHIPPING in the continental USA.
MagnaCharger Supercharger TVS 2300 for 2010 2012 Camaro SS V8
https://www.pfyc.com/CA5047.html
Unleash the true potential of your L99 powered Camaro SS with Magnuson's MP2300 TVS Supercharger Kit. This kit, designed for the 2010 to 2012 Camaro SS with the 6.2L L99 engine, is capable of making approximately 120 horsepower and 120 foot-pounds of torque at the real wheels with only 6 psi of boost. The "under the curve" power is also significantly enhanced, delivering near instantaneous boost and torque response. This supercharger is designed to deliver maximum performance while retaining the GTO's drivability and reliability.
Inside of the supercharger manifold, a large liquid-to-air intercooler keeps your Intake Air Temperatures in check while providing consistent and repeatable performance. Combined with a front-mounted heat exchanger, electric water pump, and intercooler coolant reservoir, you have a supercharger that has IATs that are typically only 20-40 degrees Fahrenheit over the ambient temperature.
The supercharger's integrated bypass valve maximizes your efficiency during cruising. The vacuum operated system allows air to bypass the supercharger and the rotors to "free-spin" under the light engine loads. During this situation, the parasitic loss of the supercharger system is essentially negated taking less than one-third of a horsepower to turn the rotors. This bypass valve also allows your supercharged Camaro SS to maintain it's stock-like drivability and fuel economy which gives you a package that delivers power without compromise.
The MagnaCharger line of bolt-on supercharger systems are engineered as a complete package. All parts come pre-assembled to make installation simple and easy. The accessory box is organized into individual sub-assemblies to ensure you don't lose track of your parts during installation. All hardware and installation manuals are included.
Magnuson's MP2300 TVS supercharger utilizes EATON's 6th Generation supercharger rotor technology and features a pair of four-lobe, high-helixed rotors with 160-degrees of overall twist, housed in Magnuson's patented high-flow housing. This creates a highly efficient package that requires less power to drive, delivers cooler discharge temperatures and is much quieter than many competitors. These superchargers are manufactured in Magnuson's TS16949 certified facilities - the highest ISO OEM quality certification standard in the market. The supercharger is built to last and backed by a 3-year, 36,000 mile warranty.
Features:
TVS2300 Hybrid-roots supercharger
Installs in one day
100% complete bolt-on system
No hood modifications are required
More power in a smaller package
180 deg. rotation of the supercharger provides a straight airflow path for maximum power and efficiency
Internal Bypass Valve virtually eliminates parasitic loss (uses less than 1/3 of a horsepower at 60 mph)
Delivers a proven increase in real world "under the curve" power
High thermal efficiency
2.4 pressure ratio capability
High helix four-lobe rotors with 160 deg. of twist
Redesigned inlet and outlet ports
Improved air-handling characteristics
Acoustically designed for noise and vibration reduction
Utilizes all factory "push-lock" connectors
IMPORTANT NOTICE & DISCLAIMER
Please read the following before purchasing your Magna Charger supercharger system or components
Some systems and components are sold for off-road use only and/or racing use (not street legal) and not intended for use on public highways, customer assumes costs and liability for installation and use. Please check the C.A.R.B. status of your system or components and local laws before ordering.
Actual products may vary from photographs shown. Magna Charger, Inc. is not responsible for any unintentional omissions, typographical errors or web site accuracy and reserves the right to make changes to packages, services, operating procedures, colors, finishes, materials, features, specifications, part numbers, pricing and to discontinue any products and/or components at any time without prior notice.
Horsepower and performance claims shown can vary considerably due to a variety of factors including but not limited to altitude, humidity, barometric pressure, outside temperature, vehicle age, state of vehicle tune, vehicle manufacturer engine tolerances, vehicle modifications, chassis and engine dyno calibration, chassis and engine dyno brand, etc.
Application
2010 2011 2012 Chevrolet Camaro SS 6.2L V8
Single Stripe Stripe Kit for 2009 2010 2011 2012 2013 2014 2015 Camaro
https://www.pfyc.com/CA1218.html
Make your Camaro look even meaner with this Single Stripe stripe kit. This kit is cut specifically for 5th gen Camaros and is sure to turn heads. Made of 3M or Avery 2 mil high performance vinyl film, each piece is precut to fit the Camaro and requires no cutting on the vehicle. Please note that we have seen inconsistencies with Avery, so we highly suggest choosing 3M colors
Shipping Note: The standard colors of Matte Black, Gloss Black, Silver Metallic, and Bright White are kept in stock and ship right away, but other colors will take up to 3 business days to ship after you order.
Warranty Information: Vinyl placed on horizontal surfaces is not warrantied by any of the manufacturers, but they will warranty vinyl placed on the sides of the vehicle for materials defects for 5-7 years. Installation errors or damage from debris, misuse, or ordinary wear from rubbing, etc. are not covered.
To see color options, please CLICK HERE
Application
2009 2010 2011 2012 2013 2014 2015 Chevrolet Camaro (all models)
2014 Chevrolet Camaro SS
R-Sport Rally Stripe Kit for 2010-2015 Gen5 Camaro
https://www.pfyc.com/CA1135.html
Designed specifically for the new Camaro bodylines, this 4-piece R-Sport Rally Vinyl Graphics kit offers aggressive styling and a great retro look. Made of 3M or Avery 2 mil high performance vinyl film, each piece is precut to fit the Camaro and requires no cutting on the vehicle. Please note that we have seen inconsistencies with Avery, so we highly suggest choosing 3M colors. The rear deck stripe fits Camaros with or without a spoiler.
Shipping Note: The standard colors of Matte Black, Gloss Black, Silver Metallic, and Bright White are kept in stock and ship right away, but other colors and carbon fiber will take up to 3 business days to ship after you order.
Warranty Information: Vinyl placed on horizontal surfaces is not warrantied by any of the manufacturers, but they will warranty vinyl placed on the sides of the vehicle for materials defects for 5-7 years. If you select carbon fiber, the material is not warrantied at all. Installation errors or damage from debris, misuse, or ordinary wear from rubbing, etc. are not covered by any manufacturer.
Closest known vinyl colors to factory colors:
Silver: 3M Silver 05M
Black: 3M Black 02M
White: 3M Bright White
Application
2009 2010 2011 2012 2013 2014 2015 Camaro LT LS SS Coupe or Convertible
Does NOT fit 2014-2015 V8 Camaro
Hockey Stick Throwback Stripe Kit for 2010-2015 Camaro
https://www.pfyc.com/CA1136.html
Designed specifically for the new Camaro bodylines, this 2-piece Hockey Stick Throwback Vinyl Graphics kit offers a great retro look. Made of 3M or Avery 2 mil high performance vinyl film, each piece is precut to fit the Camaro and requires no cutting on the vehicle. Please note that we have seen inconsistencies with Avery, so we highly suggest choosing 3M colors.
Black: 3M Black 02M
Application
Custom Painted Body Color Bowties Package for 2010-2015 Camaro
https://www.pfyc.com/5th-generation-...s-package.html
5th Generation 2010-2015 Camaro Custom Painted Body Color Bowties Package
The gold and chrome bowties from GM on the Camaro from the factory really are kind of ugly. Not to worry, PFYC has a very nice custom painted option for you looking to improve the looks of your 2010-2015 Camaro in the bowtie area. Our bowties are genuine GM parts and custom painted to your specs.
Application
2010 Camaro
2011 Camaro
2012 Camaro
2013 Camaro
2014 Camaro
2015 Camaro
2010-2015 Camaro Side Marker Blackout Kit
https://www.pfyc.com/CA1111.html
We finally have the solution to blacking out your 2010-2015 Camaro side marker lights. These Camaro side marker blackouts are made from premium ABS plastic with 3M clear adhesive built into the backing. Very quick and easy installation will take you less than 5 minutes to install the entire set. Laser cut for a perfect cut every time! Why these ABS blackout covers are better than vinyl: -Made from hard plastic, the DOT warning/lettering on the lens doesn't bubble up the cover like it will with vinyl. -High gloss shine just like the painted surface on your Camaro. -These will never fade, tear, rip, scuff or peel away. -Car wash safe - these are on like glue! Only to be removed if/when you decide to remove them. -Very easy to install, takes less than 5 minutes for the entire side marker blackout kit. -Matches our Tail Light and reverse light blackout kits, made from the same material. -Lifetime warranty. Should you lose one or break one, we replace no charge for the life of your car! These 2010-2015 Camaro side light blackouts are the best quality tinting solution on the market today.
Application
2010 2011 2012 2013 2014 2015 Camaro all models
PFYC is offline   Reply With Quote
Old 09-14-2022, 04:20 PM   #2
PFYC
PFYC's Avatar
Drives: Yes
Old 10-04-2022, 02:05 AM   #3
PFYC
PFYC's Avatar
Drives: Yes
Old 11-04-2022, 07:05 AM   #4
PFYC
PFYC's Avatar
Drives: Yes
Thank You for shopping at https://www.pfyc.com/CA1135.html
