Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - New England > Local Marketplace
Old 01-09-2020, 08:55 AM   #1
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Grille - exhaust
I have a passenger side exhaust manifold 2011 2SS. Both Cat converters, have about 12k miles on them, they are cut a few inches after the cat.
I also have a heritage grille, it is not the GM one it is aftermarket. It is plastic, black and new. But it has one crack. It is not noticeable unless you manipulate the plastic and can be repaired plastic weld or even glued I am sure, there is no pressure in the area of the crack.
Local pickup only. PM me and I can text you pictures of everything.
Greenhornet2 is offline   Reply With Quote
Old 01-09-2020, 04:17 PM   #2
chevy 3
NEcamaro5
chevy 3's Avatar
Drives: Black 2ss rs 1LE
Can you send a pic of the grill I’m interested.
chevy 3 is offline   Reply With Quote
Old 01-10-2020, 10:19 PM   #3
Greenhornet2
I don't have a picture of the whole thing at the moment. I sent you a pm with my number
Old 01-10-2020, 10:20 PM   #4
Greenhornet2
https://rover.ebay.com/rover/0/0/0?m...%2F25028901822
This is the grille
