Old 01-14-2020, 02:26 PM   #1
SlickbackJr
Drives: 2010 Camaro LT
Exclamation What should I ask for when getting my straightpipe 2010 V6
I’ve been working on my car for looks mainly and feel it’s time to get it some noise for more attention drawing. Friends have told me to get the straight pipe as it’s the cheapest option and even had a friend gift me a switch that’s also ganna get welded in so I can always have the option of quiet or loud.
I wanted to ask you guys since your more expert on Camaro’s.
I want a heavy or strong groan and not a lawnmower or a Honda with vtec
I saw you guys putting on other posts the exact sizes and stuff I gatta ask for can you guys help me out with that? Also any recommendations on what else to do to get a good strong noise going for my camaro would be appreciated.
My background on exhausts is pretty much 0 so I got no idea of anything... will I even pass smogs after this?
2010 Camaro LT2 V6
SlickbackJr is offline   Reply With Quote
Old 01-14-2020, 02:56 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
Say no to straight pipes it will sound like a weed wacker. Depends on your budget, simply going axle back will change the tone and relieve a few pounds. Changing the h-pipe to the magnaflow will lessen drone and rasp depending on your sensitivity to it. Headers will give you a performance boost and a louder overall exhaust. Long tubes will need a tune though. Shorties won’t. A quality cat-back is expensive, but the whole exhaust will work as intended.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 01-15-2020, 06:14 PM   #3
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Muffler delete would be fine if and ONLY if you grab a Magnaflow 11386 x muffler or similar and have it welded in where the stock H pipe is. Otherwise yes. It will sound awful. The Magnaflow 11386 will also keep cabin drone down if you get an actual axle back, if you choose to. Borla, Corsa, Magnaflow, MRT all have fantastic options for our cars.
It's too bad you're in Cali or you could get high flow cats and get some actual volume and depth.
DSX_Camaro is offline   Reply With Quote
Old 01-29-2020, 11:05 AM   #4
nikos30
HT5 EastSide
nikos30's Avatar
Drives: 2010 Camaro 2LT
Please read everything I say carefully below because your question brings me back in time to 2010 when I was in high school and had no idea what I was doing with almost no money...
Look at my build, I have the same exact car and had straight pipes and everything for 5 years straight. It was 100% NOT worth it at all. The drone is INSANELY BAD on the highway and sounds like absolute crap. It was so bad, people did not even want to drive with me. You seriously can't even have a conversation with your passenger. The only thing that sounded ok was startup. As soon as you touch the gas, it would actually damaged my hearing. It was honestly embarrassing until I got the resonated magnaflow x pipe to help, but it still doesn't sound as good as I'd like. Somehow I still have this car today with 120k miles and still have the same setup.
It sounds arrogant and dumb, but if I could go back I'd save all that money and find a way to get the v8. Going with some of the more restrictive magnaflows exhaust systems might be ok, but its around $1k with install. Might want to compare this cost vs selling the v6 and getting a v8. I know its "to each their own", but I'm trying to make sure you don't go the same route that I went and regret it like I do now.
nikos30 is offline   Reply With Quote
Old 01-29-2020, 04:01 PM   #5
SonicChris
SonicChris's Avatar
Drives: 2011 RS
Just a straight pipe will sound TERRIBLE. I've gone through seven different exhaust setups before finding the one I like
SonicChris is offline   Reply With Quote
Old 02-07-2020, 03:30 PM   #6
DoWork
DoWork's Avatar
Drives: 2012 Camaro 2LT & 2016 Camaro 2SS
To each there own, I personally don't think its that bad. Did it to my 2LT, and I like it. But I rarely drive it since I got mine 2016 SS. It's only obnoxious when you want It to be
DoWork is offline   Reply With Quote
Old 02-07-2020, 08:51 PM   #7
Tajefe Couple
Tajefe Couple's Avatar
Drives: Never just fly under the radar
Not trying to be rude just truly curious why you never put it back to stock in all those years if you hated it so?
Old Skool
Tajefe Couple is offline   Reply With Quote
Old 02-07-2020, 09:57 PM   #8
Vegas Bound
Drives: 2013 Sparkly Red One
Ask if it will add 100 hp.
Vegas Bound is offline   Reply With Quote
Old 02-07-2020, 11:19 PM   #9
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
i thought that it's against the law to modifi you exhaust in kommiefornia
lemontwist is offline   Reply With Quote
Old 02-12-2020, 03:12 PM   #10
xstuntman
Drives: 2012 Victory Red LFX
If you couple it with some chrome skull valve stem caps, certainly.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 02-12-2020, 05:04 PM   #11
Vegas Bound
And some HP stickers.
exhaust, help me, help me i'm a noob, help me please, straight pipe
