01-16-2020, 07:48 PM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
New DSX Triple Fuel Pump Assembly
Been working with DSX to test out their new Fuel pump assembly. Just wanted to put the word out there will be another option on the market real soon. DSX is making a couple tweaks right now to make it a bit more install friendly.
It has two hoses that mount directly into or onto the hat that run down the side of the tank, to make it easier to attach you feed/return lines. It has a jet spyhon to draw fuel from the other side of the tank. It come ready to accept your stock Fuel level sensor and arm. I’m sure you could have your order made with any pumps you want, but the one I have has 3 Ti Automotive 274 pumps, which I believe are the walbro 450s. Im working with Jannetty to tune the car, so I’ll post up some logs soon, if people wanna see it in action. Pics.. Not sure on pricing or when/if a kit or controller will be offered. Call and bug them. Ha.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
01-16-2020, 08:00 PM | #2 |
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro Join Date: Oct 2013
Very interesting, will be following this adventure for more info. Looks like an assume set up. Let’s see how the price point is.
01-17-2020, 07:41 AM | #3 |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
Since it has dedicated feed/return what happens with the stock line?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
01-17-2020, 08:33 AM | #4 |
So far, it is not a kit. So that is up to the end user. U could get the appropriate fittings to plumb it as your return, or run a new return. Up to you.
01-17-2020, 08:50 AM | #5 |
They are targeting under $1000 and that includes 3 of the 274 pumps. These are the high pressure version of the "485" pumps. The assembly will also accept the 285 Demon pumps.
01-17-2020, 07:06 PM | #6 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
How much rwhp will this support?
Any wiring upgrades needed to run triple pumps lie this?
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
01-17-2020, 07:13 PM | #7 |
Drives: 2015 Z28 Join Date: Sep 2016
Tuning In
01-17-2020, 10:24 PM | #8 |
That’s wild I literally have a brand new aux pump sitting in my studio , if this is the same price point
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
01-18-2020, 01:52 AM | #9 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
1000$ for the aux kit... or 1000$ for the triple pump.....hmmmmm
01-18-2020, 03:22 AM | #10 | |||
Each pump will need its own dedicated fuel pump relay. I bought mine from summit racing for $25 each and they include a 30amp breaker. Quote:
Feed line Return line (or fittings to use stock feed as a return) Adj FPR Wiring/relays Boost switch (hobbs) to trigger pumps 2/3 Quote:
DSX just moved into a massive new shop, but once they're setup, they plan to make this into a kit. However, they will be using the best quality stuff, so it wont be cheap. I pieced mine together for about $600.
01-18-2020, 02:49 PM | #11 |
Drives: 2013 ss2 vert l99 Join Date: Apr 2017
Pretty bad ass man. I finalized my aux pump install this morning. Thanks again :-)
01-19-2020, 09:08 AM | #12 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Looks great! Congrats to them for the venture.
What some people don’t realize is all of the accessories needed for a big fuel system. The pumps are around $1000 (regardless of the brand) then you need the plumbing, regulator, filter, e-kit, injectors, and wiring. It adds up quick. I have about $2500 in mine and the pumps were used. |
