Old 01-16-2020, 10:43 PM   #1
gmhitec
Drives: 77 z28
popping exhaust on engine braking
Hi gang, hope the new year is going well.
Thx for all the help as I find my way in the 5th gen world, last 4 cars have been 2 Z28 and 2 SS 4th gens.
2010 M6 stock except for CAI and a Billy Boat cat back.
Car is amazing compared to the 4th gens, hoping for LT's and a tune in spring. I was shocked at the price of the B&B exhaust when I looked it up, WOW!
I would have put on a chambered system, loved them on 2000 & 2002 SS.
Question, sounds great at idle and under power but under engine braking (deceleration) I'm getting burbling slight popping noise? Is this just the exhaust system or a tuning issue? The car has 55 on the clock.
While I'm at it anyone running a chambered exhaust?
gmhitec is offline   Reply With Quote
Old 01-16-2020, 11:11 PM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
The popping can be tuned out but, par for the course on a stock setup, imo.
0stones0 is offline   Reply With Quote
Old 01-17-2020, 06:13 AM   #3
Black_SS10
SomeguyK
Black_SS10's Avatar
Drives: 2010 Black 2SS/RS
It is called DFCO. Deceleration Fuel Cutoff. Makes the exhaust crackle and pop on deceleration. It can be turned via tune. I think it sounds awesome.
More to come.
Black_SS10 is offline   Reply With Quote
Old 01-17-2020, 07:51 AM   #4
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Yea the injectors are turned off after about 1-2 seconds of no throttle input. Makes the exhaust pop. It's really loud on my car, I kinda like it but it does get annoying on a longer drive. If I get irritated with it I just push the clutch in when decelerating. It also makes my A/F gauge blink red on lean, also irritating.
Greenhornet2 is offline   Reply With Quote
Old 01-18-2020, 05:09 PM   #5
superschnecke
Drives: Camaro
What makes popping? Late ignition and fuel. deceleration fuel cut off, timing and transition must be configured ....
superschnecke is offline   Reply With Quote
Old 01-18-2020, 06:10 PM   #6
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Ignition cuts off. Fuel still fueling. Fuel ignites in the exhaust.
You can see exaggerated examples with cars that they instal 2 step controllers into and set them up to blow flames when letting off the throttle
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 01-18-2020, 07:40 PM   #7
Greenhornet2
I don't know for sure but i don't think that's how it works on these. If that were the case my A/F would read rich for a few seconds at least, it doesn't, after a second my a/f goes all the way lean telling me the injector is cut off, no fuel then the popping starts. Once the fuel cuts off there isn't enough fuel for a combustion event in the cylinder, then any small amounts of fuel are pushed into the hot exhaust, hits oxygen and snap crackle pop.
Old 01-21-2020, 09:20 AM   #8
gmhitec
Drives: 77 z28
Thx for all the info, living with the popping for now, it sounds kind of cool in a way.
As long is it does not get worse when the LT's go on, of course I will have to do a tune after the install, time will tell.
Thx again everyone!
Old 01-21-2020, 10:00 AM   #9
Greenhornet2
As the exhaust gets louder the pops get louder.
Old 01-21-2020, 10:56 AM   #10
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Totally normal and you just don't notice it with stock exhaust. Some people tune to get even more decel pops.
SSEssence is offline   Reply With Quote
Old 01-24-2020, 07:35 PM   #11
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
Heavily modified 2014 Chevy SS (Sport Sedan). Mine doesn't do this anymore....wish that it did.
I'm gonna have a little chat with my tuner next week....
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 01-24-2020, 07:51 PM   #12
InFiD3ViL
InFiD3ViL's Avatar
I asked DynoSteve to adjust it in my tune (DFCO) because I love the pops and burbles, but he said No Bueno. He told me it beats up the valves.
But I already have some naturally and I am fine with that...I guess.
It's one of those things that some people love and some people hate.
Old 01-24-2020, 08:35 PM   #13
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
totally stock mine did it a little.
with the magnaflow cat back the snap crackle pop is like ear candy i love it. my tune didn't add to it or reduce it.
lemontwist is offline   Reply With Quote
Old 01-24-2020, 08:41 PM   #14
Vegas Bound
Drives: 2013 Sparkly Red One
It's fun in a busy tunnel.
Vegas Bound is offline   Reply With Quote
