Old 01-18-2020, 02:44 PM   #1
Rem0v3r
Drives: 2013 ss2 vert l99
E85 final timing
What type of final timing numbers are you guys getting on e85.. please include boost level and ethanol % for reference.
Rem0v3r is offline   Reply With Quote
Old 01-18-2020, 02:48 PM   #2
RupertPupkin
Drives: 2014 Camaro SS 1Le
Mine is TBD...
RupertPupkin is offline   Reply With Quote
Old 01-18-2020, 03:10 PM   #3
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
SBE LS3 had 16* at 17psi with E66
LSX has 15* at 20psi with E66 (so far) 11:1CR
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 01-27-2020, 11:32 AM   #4
hillshooter
Drives: 2015 Camaro SS commemorative
20 degrees at 23 pounds with 10:1 compression. E70 . I run 18 degrees though more commonly because even though I make more power on the dyno, It doesnt translate on the street.
2015 Camaro SS
hillshooter is offline   Reply With Quote
Old 01-27-2020, 01:12 PM   #5
RyangAsh
Drives: 2014 ZL1
LSA 15 LBS e80, 31-32 degrees WOT. If it's a hot night it will pull 1 degree from a 40-140mph pull..
RyangAsh is offline   Reply With Quote
Old 01-28-2020, 06:44 AM   #6
eLeSthree
Drives: 2011 Camaro SS 6sp
Good god. No meth? I know PD blowers typically run more timing, but usually in the 23-24 range. Or so I thought.
Still tuning with Ted, but seeing around 13.5-14 degrees at 19#s on E77. Zero KR, not a hint.
SBE...
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 01-28-2020, 09:04 AM   #7
RyangAsh
Drives: 2014 ZL1
SBE...
I thought he asked total timing? No, no meth...
Edit: It won't let me through a data log up to show you...car runs pretty fantastic..
It also has cooling mods and a few other mods not listed in sig..
Old 01-28-2020, 09:31 AM   #8
eLeSthree
I'm not doubting it's correct for your setup. Just surprising how much difference there is between applications.
1158whp 1017wtq.
630whp 658wtq
Old 01-28-2020, 01:44 PM   #9
stevieturbo
Drives: it changes
Sounds like a lot as others say, although the LSA is lower CR that a lot of guys seem to run these days
Was that come about on the dyno ? Or just a bit of a guess ?
stevieturbo is offline   Reply With Quote
Old 01-28-2020, 01:52 PM   #10
RyangAsh
Drives: 2014 ZL1
Absolutely no guessing. Lots of logging to get fueling perfect before adding final timing.
I'd be happy to share some data logs since I cannot seem to get a screenshot to work...lol
Old 01-28-2020, 02:04 PM   #11
stevieturbo
Drives: it changes
So it was not on a dyno to ascertain MBT ?
There is no perfect fueling....a wide range of AFR's really wont make much difference unless you go lean enough for it to go bang lol
I do have what I presume is a standard map for EFILive from a 2012 LSA car, which too seems to have a lot of timing in the high octane table. Although as I've no references as to airflow the vehicle might actually see....cant say what timing it would actually run
But the numbers in the table where higher than I would have thought. ( But I've no access to such a car, nor do I use stock ecu's...so dont know really )
The high octane table for regular fuel. I seen no corrections for flex fuel. So maybe 30deg on E could be viable. Would be nice to see on a dyno if it was actually needed or actually improving things up there, and also listening correctly for any knock
Old 01-28-2020, 03:09 PM   #12
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Ryan is the only guy I know of that's running 30+ deg on an LSA, FWIW.
Ryan's question about "total timing" makes me think maybe he's actually running 24-25 or so degrees total timing but is then adding the flex fuel spark channel to the total ignition advance channel in the log, winding up with what looks like 31-32 timing, but in fact it's actually something like 25 actual advance MINUS 6, MINUS PE adder to get back to the base high octane table value.
Is that a possible scenario Ryan? I'd think 31-32 degrees of timing would be well past MBT.
Running a stock cam with a 3.18 pulley ratio would typically have 93-oct base timing advance table in the realm of 16-18 degrees. Add maybe 5-6 degrees for E (and maybe a couple more for however the PE advance table is set up), and then you're at about 24-25 degrees delivered timing or so, assuming no IAT2 timing reduction.
Like the other guys, I'm not questioning the setup or the numbers in the logs. Maybe it's just an interpretation of numbers in the logs. Are you logging/tuning with HPT, EFI, or SCT?
I'm just genuinely curious here, not trying to incite anything or come off as anything other than inquisitive and wanting to learn.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 01-28-2020, 05:08 PM   #13
stevieturbo
Drives: it changes
It is difficult to tell from a screenshot of 1 or 2 tables from a map, what an engine may be running at any given time. Exactly what airflow and any corrections being applied.
Ultimately a datalog of the event will give the true picture, of exactly what it is running and under what load and conditions etc.
But if it has been running for some time and used hard at that without issue...maybe that's where it is happy.
Old 01-28-2020, 05:34 PM   #14
WEISHAAR37
WEISHAAR37's Avatar
Drives: 2010 Camaro 1SS
Ive tuned a good number if 7-800hp range LSA cars here at GPIin the last year or so and have never been anywhere close to 30+ degrees even on E. most cars make the best power between 19-24 degrees. once the next added degree picks up less than 8-10 hp I am done adding timing.
the only blower car ive ever seen run that much timing was a ZR1 that came in from somewhere in Nevada. it had 32 degrees. I strapped it down and quickly learned that it made peak power at 23.5 and actually lost 5hp going up to 25 degrees. car was on E and made 14# boost stock longblock LS9
3 weeks later the car came back with low compression on cylinder 5. the edges of all the pistons were completely destroyed.
this is why if I were you I would put that car on a dyno, start at 20 degrees and keep adding till it stops picking up power. I bet anything I have that you will get nowhere near 30 using this method...
Ben Weishar
Gwatney Performance Innovation
WEISHAAR37 is offline   Reply With Quote
