Old 01-18-2020, 03:59 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
Best bang for the buck beefing up engine for boooooost
Just wondering what a good setup would be that won’t break the bank, and can handle 1000rwhp and maybe beyond.. (I think regardless of the setup, it’ll still break the bank). I know get forged internals, forged block, etc, etc.. Unfortunately this is unknown territory for me...
RupertPupkin is offline   Reply With Quote
Old 01-19-2020, 07:04 AM   #2
ttshovel
ttshovel's Avatar
Drives: 12 camaro ss, 72 chevelle, 91camaro
Just rods, pistons, and main studs will hold good power for a while. The issue is the liners in the ls3 block.
Best bang for your buck is to find an iron gen 4 6.0, reuse the crank in it, put rods and pistons in that, and have something that will hold 1k whp for many years
ttshovel is offline   Reply With Quote
Old 01-19-2020, 10:12 AM   #3
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I was reading around on 1kwhp ls3s recently. It looked to me that the stock cranks are good beyond that limit. Forged rods and pistons a must. The sleeves seem to be the weak point at the level at the top of the sleeve where the water jacket is they break off. Now you could dowel the water jacket, probably the cheapest option but maybe not. Going that far you might just want to change out the block. Unless you want bragging rights for your stock block 1kwhp ls3.
Greenhornet2 is offline   Reply With Quote
Old 01-19-2020, 11:05 AM   #4
ttshovel
ttshovel's Avatar
The 5.3, 6.0, and 6.2 all share the same stroke crank 3.622
If you want a reliable aluminum block for that power you need to go to a resleeved block, fill your block, or go aftermarket. Just being honest
Old 01-19-2020, 11:24 AM   #5
RupertPupkin
Who’s doing resleeving nowadays?
Old 01-19-2020, 11:37 AM   #6
ttshovel
ttshovel's Avatar
Tkm, tsp, bullet racing engines, golen, lme, mlre to name a few
Old 01-19-2020, 01:18 PM   #7
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Hasn't been mentioned yet, but after you spend all those $$$$ to get the motor to produce 1000hp, the transmission, driveshaft, and entire rear end/suspension will also have to be replaced if you plan to actually use it.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 01-19-2020, 01:42 PM   #8
ttshovel
ttshovel's Avatar
Oh, for sure
The cost of a fuel system is outrageous!
I'm going cable drive right now and methanol. I bet I have 5k in fuel system alone
Old 01-19-2020, 04:45 PM   #9
RupertPupkin
Yup. Agreed. Looking at clutches to support the power and some coilovers. I don’t plan on going to any tracks/strips etc. Maybe just 1/2 mile events, if time permits. Other than that, it’s 100% street.
