Old 01-24-2020, 07:13 AM   #1
alice
alice's Avatar
Drives: 2010 camaro limited edition turbo
TWIN TURBO 2010 CAMARO WITH LFX ENGINE
Check out my 2010 Camaro Twin Turbo with LFX engine. Project turned out great.
YouTube https://youtu.be/qb6prNRHAlQ
alice is offline   Reply With Quote
Old 01-24-2020, 12:19 PM   #2
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
How did you manage rear mount sequential turbos?
DSX_Camaro is offline   Reply With Quote
Old 01-24-2020, 01:49 PM   #3
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
i'm checking out that and the other videos, lot of hard work and dedication all around inside and out. what are the dyno speaks or quarter mile times? also did you do anything to the LFX internals?
TommyTheCat is offline   Reply With Quote
Old 01-24-2020, 05:00 PM   #4
Syclone
Syclone's Avatar
Drives: 2015 Camaro
SWEET !
The early bird may get the worm, but the second mouse gets the cheese.
Syclone is offline   Reply With Quote
Old 01-24-2020, 07:15 PM   #5
alice
alice's Avatar
The sequential system is my own design. I've done turbo and supercharger systems all my life. The rear mounts, like STS, if done correctly, are silly simple and can spool as fast as front mounts but system design is critical for efficient operation. My sequential system has NO turbo lag whatsoever. Just like a blower. Love it. Been in operation for 8 years with no problems. A riot to drive and blows most SS's off the road. Vetted too. The little engine that could!
Old 02-11-2020, 03:44 PM   #6
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Awesome Monty!! Been a long road to this final creation! This car is truly one of a kind. every system is controlled and monitored. The sequential system is revolutionary as far as eliminating boost lag. Glad I got to work with you over the years!
Cheers!
Tech@EliteEngineringUSA.com
Elite Engineering is offline   Reply With Quote
Old 02-12-2020, 12:48 PM   #7
alice
alice's Avatar
Cheers!
I credit you, with all of your vast knowledge of the 3.6 V6 engine! Without your help and your products, this project would never have turned out this good. Whenever I have a question about this revolutionary engine, I call you because I know you can give me accurate and informative information. And thanks to the Elite catch cans, my intake valves stay clean!! Thanks for the help and compliments!!
Old 03-10-2020, 03:25 PM   #8
15RS2NV
Ponies are for girls
15RS2NV's Avatar
Drives: 2015 RS LFX Red Hot A6
My question is why you changed from the original LLT V6 to the LFX?
H&R 1.8/1.7” drop, Overkill 80mm + intake ported by AFS, 1" insulator MACE, Accel Super Coils, THR cai, JET MAF sensor, Hurst shifter handle, GPP strut tower brace, CI ice cube tray hood vents (functional) @SemperFiCamaro
15RS2NV is offline   Reply With Quote
Old 03-10-2020, 04:07 PM   #9
IKILLEDSUPERMAN_ZL1
Drives: 2011 Camaro SS
Awesome car.
2011 Camaro 2SS, 6.0 iron block forged bottom end, Dart heads, BTR intake, Huron twin turbo kit, Summit stage 3 twin turbo cam, Circle D stage 4 6L90, 3800 FTI converter. BMR suspension, Viking coil overs, Fore triple pump fuel system.
IKILLEDSUPERMAN_ZL1 is offline   Reply With Quote
Old 03-13-2020, 07:53 AM   #10
alice
alice's Avatar
The reason I changed from an LLT to LfX was primarily for the Delphi ECM controller, as well as the new head design that eliminated the exhaust manifolds and the other modifications GM made to the LFX engine. No modifications to the engine whatsoever, stock.
Old 07-03-2020, 05:29 PM   #11
ccalderon210
ccalderon210's Avatar
Drives: 2011 Victory Red Ls
So your car has and lfx ? What did you need to get this to work beside the motor and controller? Radio work, air conditioning? Any compromises regarding the interior? Is everything fully functional? Lfx swap in to an llt car would interest me if my motor ever blew, so I thought I'd ask
2011 LS A6
Brembo SS brake swap, eighbach lowering spring prokit 1.3" drop, K&N typhoon 69 series intake, mace ported throttle body, intake manifold spacer, long tube headers->no cats->stock ss exhaust
ccalderon210 is offline   Reply With Quote
Old 07-04-2020, 07:54 AM   #12
alice
alice's Avatar
Everything works. No issues. I drive the car everyday to work and back and never had any problems. Makes a great conversion. I had to install a matching automatic transmission, as well. VATS will have to be disabled to make any conversion work.
Old 07-04-2020, 08:02 AM   #13
KalCorp
Space Coast Camaros
Drives: 2012 Camaro Vert
Nice :-)
I got Eng Mount Twin Turbo setup :-)
Pic's @ https://www.facebook.com/NBECAMARO/
KalCorp is offline   Reply With Quote
Old 07-23-2020, 02:48 PM   #14
Little Walter
Drives: ZL1
Super nice. How much horsepower?
Little Walter is offline   Reply With Quote
