Old 01-25-2020, 07:27 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
Speaker outage
Driver side speaker goes out when I go over bumps. Now won’t come back on. Ideas?
RupertPupkin is offline   Reply With Quote
Old 01-25-2020, 08:31 PM   #2
Leo72793
Drives: 2011 2SS/RS
probably trashed or rotted. gm speakers suck.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 01-25-2020, 08:59 PM   #3
RupertPupkin
I have Boston acoustics.... still not the greatest, but slightly better than the GM speakers....u think it could be the amp?
Old 01-25-2020, 09:40 PM   #4
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
it could be so many things it's impossible to speculate.
lemontwist is offline   Reply With Quote
Old 01-26-2020, 11:46 AM   #5
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
Your going to have to investigate it. Most likely not the amp if all the other speakers work. Take the door panel off and see if the speaker wire is loose or the speaker is blown. If it’s blown i have a set or Boston’s i can sell you cheap.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 07-14-2020, 10:43 AM   #6
kj42
Drives: Camaro 2013
Most probably blown off and got the last beating from the bumps.
If you are lucky, it may be a wiring problem. Why not try to replace front speakers with each other to diagnose the problem?
kj42 is offline   Reply With Quote
Old 07-15-2020, 07:35 AM   #7
RupertPupkin
Too lazy. Lol.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
Old 07-16-2020, 07:58 AM   #8
JimE
JimE's Avatar
Drives: 2013 2SS/RS/1LE
Too lazy. Lol.
In which case, take it to a stereo shop and let them do the work.
JimE is offline   Reply With Quote
Old 07-16-2020, 11:00 AM   #9
RupertPupkin
Too broke also. Lol. I know how to swap the speakers. It’s more of finding the time.
730whp: 630Trq
