Old 01-25-2020, 10:44 PM   #1
Tjet
Drives: Camaro RS
Instrument cluster 2017 Camaro RS
So i went to turn on my Camaro and i noticed that my instrument cluster went out and was just went black and i tried cutting off and then back on but still wasn’t coming on and now certain buttons on steering wheel not working and I’m not able to tell the mileage on car or how fast I’m going was wondering if anyone know a solution or how to fix the problem or have it happened to anyone else i tried unplugging and plugging back fuse but still didn’t work if anyone could help would gladly appreciate it
Tjet is offline   Reply With Quote
Old 01-26-2020, 04:31 AM   #2
fhrex
Drives: 2011 Camaro 2LT/RS
it may be a software issue. a GM dealer can check and reprogram your IPC if that indeed is it
fhrex is offline   Reply With Quote
Old 01-27-2020, 03:43 PM   #3
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
You'll have more luck on camaro6.com forums instead of the 5th gen site, but that could be caused by so many things. you just need to bring it in for a diagnostic if you don't have proper scan tools and electrical equipment for testing everything.
TommyTheCat is offline   Reply With Quote
2017 camaro, camaro rs, instrument cluster, instrument panel
