Old 01-26-2020, 07:15 AM   #1
rfs
Drives: 2010 ss camaro
OPINIONS/ADVICE NEEDED- RCR dragmaster cam for my 2010 LS3
Specs: 223/231 .625 I/E 111 lsa.
I am looking to cam my 2010 LS3, I will be upgrading my timing chain and oil pump, lifters, as well as the obvious -ex. valve springs -(I am at HIGH mileage).
My installer has this cam he pulled out of his g8, and says it will work great, but "may be slightly too aggressive" for what I want. I have been doing some research and this cam is well known in the g8 community but what about running this in my camaro? Would it have proper clearance? What could I expect (lope,gain,idle,overall drivability?)
Thanks in advance
rfs is offline   Reply With Quote
Old 01-26-2020, 09:31 AM   #2
Juiced1
Drives: 2012 2SS CAMARO 45th
Never heard of RCR but the cam specs are not very wild at all. In fact that is a smaller cam then the TSP and GPI stage 1 cams. It'll get some lope and drive fine. Power increase will be decent/modest. If you are a manual car (I'm assuming you are) you could get away with something more significant without effecting drivability.
Juiced1 is offline   Reply With Quote
Old 01-26-2020, 10:28 AM   #3
RupertPupkin
Drives: 2014 Camaro SS 1Le
OP. Rick Crawford is considered a god in the G8 world. He spec’d my cam for my G8 back in the day. Like Juiced said, it’s on the smaller side. Just do your springs, trunion, and all the other goodies to be well rounded in your build. I would say 460-470rwhp depending on dyno, I have the tick polluter stage 3 cam (233/248 | .627”/.612” | LSA113+5 ) and she drives smooth as butter.. It’s all in the tune.
Polluter cam: https://youtu.be/xesLlrtA5bM
RCR spec cam in LS3: https://youtu.be/S_JuYgOGkUg
RupertPupkin is offline   Reply With Quote
Old 01-26-2020, 02:47 PM   #4
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
It's a small cam: you won't have any problem with drivability.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 01-26-2020, 08:57 PM   #5
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
My Vengeance Vsrp II was 227/235 and it had fantastic manners.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 01-26-2020, 10:10 PM   #6
InFiD3ViL
InFiD3ViL's Avatar
A good part of the driveability and street manners will come down to the competence of your tuner.
223/231, cam fitment, ls3, rcr
