Old 01-29-2020, 06:43 PM   #1
hou30guy
Drives: 2011 convertible 2ss/rs
Need help with next upgrade
I have a 2011 Camaro with 410 stroker 10 rib maggie with all supporting mods,with 4k stall making 732whp and 757tq on a conservative tune at 15psi and 19 degreesof timing i believe, i already swapped out my 6l80 for a 6l90 that i personally upgraded all the common failure parts. Now im trying to see if i should go truetrac locker or 1000hp axles. Im sure most or all would say both, but i will be doing one at a time. Its my daily driver, no track or dragstrip just occasionally light to light and hwy pulls. Already has 18" drag pack too. its a convertible, and if i remember right the axles are stronger or bigger in mm than the hard tops but i couldbe wrong. And if your wondering why i have a 4k stall with a maggie its because of my cam 244/266 118+4 pds blower cam that calls for 3800-5k stall lol
hou30guy is offline   Reply With Quote
Old 09-25-2020, 11:30 AM   #2
abshire1006
abshire1006's Avatar
Drives: 2012 camaro ss
If your not having issues with axles I would say diff first, i have been through 3 axles in the last 2 years, and even tho I know I need to go with 1000hp axles, you don’t wanna upgrade axles and have your diff mess up. A stock axle with a lifetime warranty is a lot cheaper then a stock diff or upgraded one
2012 SS, Magnuson supercharger, leathel racing night fury cam, ported throttle body, long tube headers,ACT twin disk clutch, BMR suspension, 620 RWHP 580 ftp 11.8 @121 1/4 mile time on 295/35/20 nitto nt555g2 tires
abshire1006 is offline   Reply With Quote
Old 09-25-2020, 03:06 PM   #3
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
leave the axles as your weak point, they are the cheapest. Once you pop one upgrade to 1LE axles. Beef your axles up and your weak point changes to the trans or diff. I know of folks running stock axles at close to 1000whp on the track. No hop = no break
Greenhornet2 is offline   Reply With Quote
