Old 02-02-2020, 02:49 PM   #1
computerfreak07
Drives: 2012 Camaro 2SS 45th Anniversary
What is This and How Can I Remove It?
I recently washed my car and noticed that underneath the passenger's door on the bottom panel there is this tan-colored concrete-looking gunk. I was able to get a lot of it off near the rear wheel where it was lightly-splattered, but near the front wheel, I can't make any progress. Any ideas?
computerfreak07 is offline   Reply With Quote
Old 02-02-2020, 04:00 PM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Soak it with soap and water then use a plastic scraper and try getting it off that way.
Bigdumogre is offline   Reply With Quote
Old 02-02-2020, 04:31 PM   #3
Overflow
Space Shuttle Aficionado
Drives: 2016 Camaro 2SS
I've gotten this stuff on my car before. I also use some tar removal. It helps a little, but be ready to use some elbow grease.
Old 02-02-2020, 10:30 PM   #4
Cyber/Orange10
Cyber/orange10
Cyber/Orange10's Avatar
Drives: 2010 2SS 96 CE LT4, 12 CRUZE ECO
Send a message via AIM to Cyber/Orange10
Looks like road marking paint...use plastic scrapper and tar remover
Cyber/Orange10 is offline   Reply With Quote
Old 02-06-2020, 07:28 AM   #5
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Goof Off - Overspray Remover in a spray can should work well with that. Had to use it on my other vehicle and it worked very well.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 02-06-2020, 08:30 AM   #6
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
The polymeric sand they use for interlocking bricks looks like that.
That stuff sets after it gets wet.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 02-06-2020, 09:08 AM   #7
lbls1
lbls1's Avatar
Drives: 2002 Camaro SS SOM; 2015 Malibu LTZ
Concrete splatter from the road. Soapy car wash solution can clean up some of this; I would try a claybar with a lube spray, then follow up with concentrated at wash soap with water and a clean sponge.
Good luck.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
'15 Malibu LTZ 2LZ Turbo
'14 CAMARO ZL1 Blue Ray Metallic
'25 Silverado 1500 High Country 6.2L
lbls1 is offline   Reply With Quote
Old 02-06-2020, 09:18 AM   #8
Vegas Bound
Drives: 2013 Sparkly Red One
WD-40 on a sponge. Light circular pressure.
Vegas Bound is offline   Reply With Quote
cleaning, concrete, exterior
