Old 02-03-2020, 09:08 AM   #1
g1o1101
g1o1101's Avatar
Drives: 2011 Camaro 2SS L99
Exclamation Engine pull
Anyone have a good guide for pulling the engine on the SS. Specifically the L99 but a guide for the LS3 would be helpful also.
g1o1101 is offline   Reply With Quote
Old 02-04-2020, 09:58 PM   #2
MaverickLS7
MaverickLS7's Avatar
Drives: 2015 1LE
It's a lot to list honestly, but it goes by pretty fast when doing it. You can message me if you need some help.
MaverickLS7 is offline   Reply With Quote
Old 02-05-2020, 02:07 PM   #3
g1o1101
g1o1101's Avatar
Ahh okay will do man. The reason I’m pulling it is because I have an oil leak near the oil cooler , filter and there’s some drops that accumulated by the bell housing and block so I’m worried it might be the rear main. I will post another thread tmr with pictures of the leak tomorrow to get some advice.
Old 02-05-2020, 06:58 PM   #4
MaverickLS7
Drives: 2015 1LE
Gotcha, hoping for you it's not rear main. Oil cooler and such is accessible while engine is in the car so thats good.
Old 02-05-2020, 09:55 PM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
If it is the rear main, wouldn't it be easier to pull the trans?
Vegas Bound is offline   Reply With Quote
Old 02-06-2020, 12:37 AM   #6
g1o1101
g1o1101's Avatar
Possibly however I’m doing a DOD delete with a cam and upgraded oil pump so pulling the motor out would make everything much easier and if it is the rear main I’ll have access to it so I think it’s my best option right now.
Old 03-22-2020, 01:06 PM   #7
jacksaigon
Drives: Black Camaro
I hope you could share what you found of the leak. I'm eager to know so I could plan of how to fix the stubborn oil leak of mine. Good luck man!
jacksaigon is offline   Reply With Quote
Old 05-09-2020, 05:41 AM   #8
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
its not that bad, 3ish hour job. I deleted my oil cooler because mine was leaking too.
Forged LS3, FED M311 heads, CAI Inc, ARH 1 7/8, Corsa Xtreme, Taylor Wires, MGW Shifter, Street slayer twin carbon clutch, Tick braided clutch line & speed bleeder, ZL1 Diff Swap, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Carslyle racing 15in conversion, Whipple, LPE dual fuel pumps, Rx catch can, Id1300x, Alky Control
BigMatt is offline   Reply With Quote
Old 07-02-2020, 11:43 AM   #9
g1o1101
g1o1101's Avatar
Pulled the motor did the DOD AFM delete and VVT delete. Put on stage 2 TSP cam kit and new oil pump all new gaskets as well. Pretty easy pull once everything is out the way. Started by taking radiator out and the accessories that where accessible. I didn’t have to disconnect any AC lines or remove the condenser just moved it off to the side. Moved entire wiring harness out the way. Removed everything from the engine except the heads and front timing cover and harmonic balancer. Used some grade 8 bolts and pulled the motor from the valley cover.
Old 07-02-2020, 11:44 AM   #10
g1o1101
g1o1101's Avatar
First time ever pulling a motor and ever building one as well. I recommend the how to rebuild Gm Ls series engines by Chris Werner great guide.
engine pull, l99 to ls3
