Just absolutely ridiculous
Per my tuner,
On an L99 car with a power adder, bolt on's and torque converter, your supposed to use the PADDLE shifter's when going down the dragstrip. They are adaptive and will lose all that lag they come with from the factory over time. ![]() Also by removing 110 lbs of weight from the car, and 36 lbs of rotational weight from the front wheels and driveshaft, you shouldn't get ANY GAIN whatsoever in your ET. ![]() HP tuners here I come.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles. |
Instagram: Sangstah
Paddle shifters are definitely slower on the dragstrip. There is a noticeable lag shifting from the paddles vs the trans shifting for you.
#3 | |
Sucker Punch
Drives: 2013 Black ZL1, 2022 Silverado ZR2 Join Date: Jul 2014
Tap shift is not adaptive and that is why it is slower. When a 6l80/6l90 is in normal or sports mode the computer anticipates the oncoming shift and it prefills the clutch packs, when it’s in tap shift it has no way to know when the command to shift is coming so it can’t prepare for the shift. These transmissions are complicated on how they hand off from gear to gear. If your tuner does not understand this, you need a new tuner.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
![]() Drives: 2010 2SS/RS A6 Join Date: Aug 2019
Care to share who the former tuner was, Joe? Might can save me some trouble in the future being a NC guy
2010 2SS/RS
CAI Intake Phastek Air Scoop Kooks w/ HF Cats Corsa Sport DynoSteve Tune |
#6 |
Sorry, he pays money to advertise on here, and that is more important than honesty and values.
Still researching for someone who shares the same morals/values as I do.
#7 |
![]() Drives: 2013 ZL1 Join Date: Dec 2015
So if the 6l80/6l190 are so good, why do folks swap to a th400?
#8 |
People swap because they have exceeded the HP/TQ capabilities of the stock transmission, I'm not even close to that level.
I have no current need for a th400, what I do have need of is a tuner who doesn't tell me lies.
#9 |
![]() ![]() Drives: 2014 SIM 2SS Join Date: Sep 2015
PCM of NC or Heintz Racing if you're trying to stay local.
Pat G does an excellent job of remote tuning. Several of their previous posts mention RDP, I assume that's who they are referencing. |
#10 | |
I contacted both already. PCM in Mooresville said they have more work than they can do. I did have a good conversation with Jeff @ Heintz racing, waiting for him to get back with quote for everything I need.
#11 |
I talked to a guy with a 6th gen at a cars and coffee this past Sunday that had Heintz put in a stage 3 cam and stall and spoke very highly of them and their work. They are on my list to deal with as well.
2010 2SS/RS
#12 |
![]() ![]() ![]() ![]() ![]() Drives: Never just fly under the radar Join Date: Jul 2015
Only 3 gears to shift, and built they handle power great. Much like old drag racers used a 2 speed power glide, no shift delays if your not shifting. Downside no overdrive, 3rd gear is 1:1 with a 400.
Old Skool |
#13 |
Not what my tuner said, he said they are slower and can't be tuned to be faster. The computer is set to shift at certain RPM's and it knows that and does the job quickly, as the paddles won't. Believe me I tried, you tap the button and notta, then about 200rpms later, shift. And that was on a tuned tranny after the header install and tune.
#14 | |
