Old 02-07-2020, 09:45 AM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Too loud. Too raspy.
If I could change one thing on my car, it would be the exhaust sound. It's too damn loud for my taste. I prefer a deep rumble that you get from a chambered flowmaster muffler, but I dont want to lose substantial power or create unwanted back pressure.
I have TSP 2 inch headers with 3 bolt flanges welded on. Then I had my exhaust guy Rob, fab up 3 inch piping to a true 3 inch X merge, then 3 inch all the way back to Magnaflow straight through mufflers, 3inch in/out.
I can't think of a system that would flow better, besides open headers or cut outs, so any change I make, I will likely lose a few HP. But I'm ok with that if I can quiet it down by a good amount.
I fish quite often out of Port Everglades inlet and leaving that house on saturday mornings at 4am is impossible in my car.
Looking for recommendations for Mufflers and or resonators (must be true 3inch all the way), to quiet things down. The more quiet the better.
Sounds clips would be great.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 02-07-2020, 09:50 AM   #2
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Magna flow makes a resonated x pipe , has glass mat packing. I would give that a try
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 02-07-2020, 10:04 AM   #3
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
yup, magnaflow resonated x-pipe will help...the opinion seems to be a 20-30% drop in volume (and less drone, if that's an issue for you). Otherwise you could add hi-flow cats, and switch to borla "touring" mufflers.
POWERFREAK is offline   Reply With Quote
Old 02-07-2020, 10:12 AM   #4
eLeSthree
in 3 inch? Got a link? I cant find it on their website.
1158whp 1017wtq.
630whp 658wtq
Old 02-07-2020, 10:14 AM   #5
xc_SS/RS
Drives: 2010 Camaro SS/RS
Try bullet resonators
Dynomax has a 3” x pipe muffler but I think it’s pretty long
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 02-07-2020, 10:14 AM   #6
eLeSthree
Oh I found it, they call it a muffler.
https://www.magnaflow.com/products/1...rmance-muffler
Thanks
1158whp 1017wtq.
630whp 658wtq
Old 02-07-2020, 10:41 AM   #7
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
An option for you might be a more stock exhaust from the header back with cutouts. I have a2.5 catback with borla ataks and it is not too bad once just cruising down the road but it is mighty loud on startup. Once warmed up it idles tame and under light throttle it is tame.
Greenhornet2 is offline   Reply With Quote
Old 02-07-2020, 10:45 AM   #8
xc_SS/RS
Thanks
That might not fit in the center tunnel. The one that fits is a 4x9 muffler and that’s 5x11 lol that’s a big muffler
2010 2SS/RS
Old 02-07-2020, 10:58 AM   #9
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
The magnaflow resonated x pipe that fits in the tunnel is a 2.5” unit about 14” long. I used it once and it does cut volume by 30%. I now have the magnaflow 3” competition catback. I have shorty headers and a stage one cam so the sound is good. I did have hiflows and it was just a bit louder with those. The catback does have a bit of boom and drone, but fabbed up some j pipes and killed the drone and boomy sound from the 3” pipes. Sounds more clear now. And has the deep v8 rumble
VR Baron is offline   Reply With Quote
Old 02-07-2020, 11:25 AM   #10
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Just turn up the radio
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 02-08-2020, 12:16 AM   #11
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
Borla.....
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 02-08-2020, 12:33 AM   #12
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
I have the magnaflow competition catback which is a resonated x pipe and straight pipes. Its fairly quiet and has a deep tone. It's pretty loud on cold starts though.
https://youtu.be/gLO9r3T51Fg
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91
Bo White throttle body Magnaflow Competition Exhaust
12.391 112 MPH 10/05/19
StingrayblueSS is offline   Reply With Quote
Old 02-08-2020, 09:59 AM   #13
RedRyder
RedRyder's Avatar
Drives: 2010 VR 2SS/RS M6 Camaro
I have the 3" Magnaflow resonated X-pipe since I was like you and wanted less restriction. It's a big muffler, doesn't fit with a tunnel brace, and will be your lowest point on your car. I had a 1" drop and I scraped it a lot so I adjusted my coilovers and raised it to like a 3/4" drop and it's much better.
I think if you have a really good exhaust guy you might be able to angle it upwards a bit for more clearance without getting too close to the driveshaft.
It does cut down the volume/drone by a good amount though. No regrets.
RedRyder is offline   Reply With Quote
Old 02-08-2020, 10:12 AM   #14
RedRyder
RedRyder's Avatar
Also just noticed you've got the longer version linked, there's a 24" version that I have: https://www.magnaflow.com/products/1...rmance-muffler
