![]() Drives: 2014 2SS RS LS3 Join Date: Jul 2014
Intake valve spring broken - how lucky am I?
Car has been flawless for 5+ years...then an intake valve spring on cylinder #8 broke just after warranty expiration
![]() Reading similar threads, it seems I was super lucky, as there appeared to be no damage other than the spring -- they did a compression test after replacing it and the cylinder was at 155psi. This happened after downshifting a couple times coming off from the highway. My CEL starting flashing, service stabilitrack came on, car went into limp mode shaking bad, felt like it was going to stall, and I could smell gas. I limped it home 2-3 miles then got it towed to the dealer. The odd thing is that my code reader said P0300 (multiple cylinder misfires), so I figured it was a bad sensor or something. However, the dealer tech said that both #5 and #8 were misfiring, but #5 held compression well (#8 had no compression). After replacing the #8 spring, everything was good. Can a bad spring in one cylinder cause another to misfire somehow? PSA: Use brakes instead of downshifting. Don't be an idiot like me that tried to save some pad a brake job is way cheaper!
2014 2SS Black/IOM --- RS -- NPP -- Short Throw Shifter -- Sunroof -- Nav
Mods: CAI Inc. CAI Elite Engineering Catch Can |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
![]() Within reason, downshifting should be fine for some engine braking.
#3 | |
The tech suggested that I must miss shifts, downshift hard, or just beat the crap out of my car. Then I told him I just replaced my factory tires after 39k miles
Drives: 2010 Camaro 1SS LS3 Join Date: Jan 2015
I was cruising on I-15 one morning... 77mph, when all of a sudden the car started shaking and started sounding really bad... something definitely broke. Check engine light came on...
I put it in neutral and coasted towards the nearest exit, parked around the corner in a safe place and shut it down. When it got lighter out, I called for a flat bed truck and my car ended up at Allen GMC out of Laguna Niguel. The service dept said on quick that somethings wrong with Cylinder 3. Had a P0300 code. Further inspection and the verdict was that one of my rocker failed, killing the spring too. Mine happened on Cylinder 3. Allen GMC took good care of me getting my car back and fixed in 24hrs. I felt lucky too because there was no other damage. Car felt great and I left there happy. This at 83k miles... I'm now at 167k+ and still going strong. Yes, this happened to me too... but the bright side is that apparently your car too will be okay. How many miles on yours, bout 40k when this happened? To add, I too was out of warranty... end of the day 550 out the door... |
#5 | |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Mar 2014
I had this happen when I first got my car. #8 intake spring broke. They replaced the spring and it fired right up and drove/idled perfectly. Still going strong at 117k lol this happened in 2014
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
#7 |
![]() Drives: 2010 2SS/RS M6 IOM, 1995 Blown Z28 Join Date: May 2009
My #6 intake valve spring broke Monday; was at ~1,200 rpm under light load in a parking lot. 163,000 miles so can't complain.
2010 2SS RS M6 Inferno Orange Metallic
1995 Z28 - blown, intercooled and nitrous injected - Sold 1968 Camaro - Sold 2019 Corvette Grand Sport ![]() |
#8 |
![]() ![]() Drives: 2011 2SS/RS LS3 VR Join Date: Aug 2009
My Camaro is currently at the dealership having all the valve springs replaced.
Yesterday as I was driving into work I experienced the loss of power and some noise. I was lucky it happened as I was pulling into work so I parked it and had it towed to the dealership. This is the second valve spring that has broken on me. The first went in 2015 and was replaced under warranty. First to go was cylinder 2 intake, second was cylinder 4 intake. I'm sure I got a bad batch of valve springs with my LS3 so I decided to replace them all. This car is my daily driver and I'm mostly to and from work and around town. Yes I get on it from time to time but I don't beat on it. I'm only 58000 km's (36250 mi.) in and wish I would have made more of a case to replace them all under warranty. Am I lucky there isn't a bent valve or damaged piston? |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
You could always put a lower lift cam in your car and they would stop breaking =)
#10 |
Or replace the springs yourself. The factory cam is not a high lift cam. Springs and pushrods in the stock engine are weak links.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts, 1.4" BMR lowering springs ZL1 factory rims misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete |
#11 |
That's crazy, valve springs with install go for $500-$700!? The springs are about $100 without install.
#12 |
If you are driving HP cars at least part of the time as they were intended to be driven, 30 to 40k miles valve spring replacement is cheap insurance on a basically stock or header/intake modded LS3 or L99. Sooner if car is raced at drag strip, autocross or road course. Just part of the regular maintenance of a high performance car.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
#13 | |
I assume when the dealer does a spring change that they don't replace seals, retainers, or locators either - unless requested and added to the total cost. Kinda a 'while your in there' thing.
#14 | |
